Cleaning the salks
ricardojoa
Cleaning the salks
« on: 18 May 2013, 02:04 pm »
Hi guys,
can i get a suggestion on what do you guys use to clean your salks?
Ever i got them, i have never cleaned them. I mainly dust them over periodically. But i thought they will get a fresh look by applying some furniture polish. But just like to get an opinion first.
Thank you.
jsalk
    • Salk Signature Sound
Re: Cleaning the salks
« Reply #1 on: 18 May 2013, 02:23 pm »
We do not recommend furniture polishes or waxes.  These will not penetrate the topcoat and will never get to the wood itself anyway.  So there is no advantage to using them.  They will only attract dust faster.
Here at the shop, we use Meguiar's Quick Detailer, available at any auto parts store.  Spay a little on a soft, lint-free cloth and wipe down the surface.  This is used to wipe down cars and works great on lacquer finishes.  It does not leave any residue to attract dust.
- Jim
ricardojoa
« Reply #2 on: 18 May 2013, 02:27 pm »
Thanks Jim,
never thought auto detailing products would actually work.
