ST Spikes and hardwood floors
0 Members and 1 Guest are viewing this topic. Read 5653 times.
WGH
Re: ST Spikes and hardwood floors
« Reply #20 on: 15 Jun 2013, 01:26 am »
Spend thousands on a speakers, electronics, cables and cheap out on glides - I don't think so. Eight reasons why my HT2-TL's sound so awesome:
Herbie's Cone/Spike Decoupling Gliders - $14.89 each
http://herbiesaudiolab.net/spkrfeet.htm
And they look cool too.
Wayne
tknx
« Reply #21 on: 15 Jun 2013, 01:43 am »
I'll be honest, I am not sure I even believe in speaker spikes...
From what I've read, there is a lot of misinformation: whether they couple or decouple; when they've done vibration tests, spikes made vibration worse; and if you wanted to eliminate vibration, better to use rubber feet. May just go with no feet for now...
svadas
« Reply #22 on: 15 Jun 2013, 03:24 am »
As previously suggested, I'm using these from Lowes for about $4.  They are nice as you can move the speaker without scratching the floor and the spikes fit right in the metal tab.
 http://2.bp.blogspot.com/-HBgK1vkSqnY/UDKUNt7N7hI/AAAAAAAAAIo/B437Kimkv3A/s1600/Waxman+4718795N.jpg
glangford
« Reply #23 on: 15 Jun 2013, 10:19 am »
That's what I did. I just put some felt furninture pad stick ons over the spike holes and let it go.
DeanZ
« Reply #24 on: 20 Jun 2013, 01:51 pm »
My home theater has a tile floor on concrete. With my HT1-TL's I tried some teflon pads under the Salk spikes, I tried butcher blocks and although they protected the floor, the speakers were also ending up too high for my seating. I removed the blocks and the spikes and put 4 of these under each speaker:
http://www.grainger.com/Grainger/MASON-NeopreneCork-Anti-Vibration-Pad-5C027?Pid=search
They are cheap and the sound improvement has been significant!! I  now have these under my mains, under my new Salk Sub (no spikes here either), and recommend you give them a try. Not much to lose at this price. I believe they also sell them in black, but to make them disappear, I just painted the cork sides with some flat black paint.
WntrMute2
« Reply #25 on: 4 Jul 2013, 12:49 pm »
I use these felt sliders.  They are backed by metal so the spike won't drive through.  I superglued a washer to keep the spike centered in the slider.  Works great and all parts are available at Home Depot.
