0 Members and 1 Guest are viewing this topic. Read 32446 times.
So if you keep the frequencies the subs are producing below, say, 80 Hz, you can get away with subs in mono. Why though? What's the advantage?
That's a great question! One aspect of the answer is the interaction of subwoofers with room modes. If you look at the in-room frequency response of a single sub, it will have peaks and dips due to room modes that can be quite severe (say +/- 15 dB). If you take another subwoofer supplied with the same signal but with a different location, the peaks and dips due to room modes will in general be at different frequencies.If you were to try to EQ that first sub by itself, the dips would need to be either ignored or boosted. If they are ignored, they will of course remain. If the dips are boosted, this places some tough demands both on the subs and their amplifiers, as they are both being over-stressed in an attempt to "fill in" the suckouts. Also, this attempt to fix the response can cause the response at other room positions to be worse than with no EQ.Now suppose a second sub with the same signal applied is added in a different location. Because of room modes, it will typically have reasonable output at the frequency for which the first sub has a suckout, so this sub can "fill in" the suckout of the first sub, at least partly, without having to send boatloads of power to the first sub.It's kind of like the idea of modern portfolio theory from investing, in which many investments with different characteristics are combined to smooth out variations in the valuation of a portfolio with time compared to a single investment. Only you have multiple subwoofers that interact with the room modes in different ways, such that they combine to have a flatter frequency response than any individual subwoofer. Another beneficial side effect is that multiple subwoofers tend to make the bass response variation with listening position less than for a single sub. There is actual data from Welti and Devantier and others showing this effect.
So, do we know for sure that two or more subs run in mono cancel room modes to a greater extent than if run in stereo?
Andy!Yes. I agree. Thank you for that. I was looking up various articles in my copy of Floyd Toole's book "Sound Reproduction" and happen to run across this one, Chapter 13.3.8, which is available from a google search regarding, ahem, stereo bass (sorry Jim!):Stereo Bass: Little Ado about Even LessI found it interesting that Dr. Toole said this:Most of the bass in common program material is *highly correlated or monophonic* to begin with, and bass management systems are commonplace, but some have argued that it is necessary to preserve at least two-channel playback down to some very low frequency. It is *alleged* that this is necessary to deliver certain aspects of spatial effect. Experimental evidence thus far has not been encouraging to supporters of this notion (Welti, 2004).But heh, what does Dr. Toole know ?Bye,Anand.P.S. I'm still going to call the studios though - to be thorough, I have a feeling that the devil is in the details.
Jim postulated that if you drive dual subs from mono signal soundstage collapses but doesn't if you supply stereo signal to separate subs, left and right.That is why it doesn't make sense to say its about distortion.
Yes, it looks like Earl is concentrating on sealed boxes now.
Most of the bass in common program material is *highly correlated or monophonic* to begin withI have a feeling that the devil is in the details.
I think a single sub of high quality well placed can sound better than two subs of more modest quality.
Hi Anand,Indeed it is. I highlighted Toole's caveat. If one is a typical audiophile listener, as I have encountered by the hundreds (thousands[?]) at shows, meets, events, demos, etc, etc. over the years, then read no further.If not, http://www.davidgriesinger.com/asa05.pdf.I've been hesitant to weigh in on localization and "stereo" bass, etc., because "it depends" and is so largely inapplicable.cheers,AJ
After a PM discussion with Jason and Anand on the subject of how bass is recorded and bass in recordings in general, I figured I'd post one of my replies:If I may say so, all of the Soundkeeper Recordings are made in real stereo, with the entire event picked up by a single pair of microphones arranged in a stereo array. The mic array itself provides all the types of cues we use to localize sounds (not just the amplitude differences of pan pots but also timing differences and frequency differences). No pan pots are used in the production. I've used this same technique for classical music, jazz and rock. Acoustic bass (unamplified) is picked up by the same stereo pair that "hears" everything else. In the pop/rock recordings, the electric bass amp is picked up by the same stereo pair. Again, no pan pots. In fact, no electronic mix at all because the "mix" is achieved acoustically *before* the Record button is pressed. Instead of pushing faders, we move the players (and amps) around the stage to achieve what we want. Hope this helps.Best regards,Barrywww.soundkeeperrecordings.comwww.barrydiamentaudio.com
So on one hand you say it is too hard to do, but then tout your studio for recording in pure stereo, interesting....BTW, many studios mike as you suggest....go to the JackShit Video I posted as an example....I agree that some less well equipped studio's will short cut and pan, but these days most recordings are digital and transfer to CD format and not vinyl, with the recording/mixing techniques being different. Loudness wars was and still is a reality, but that just means more compression and less dynamic rises within the music. Jim
AJ,Thanks for the link, a great read so far. Earl stopped making ported mains before 2007 fwiw.
