HDMI Audio
0 Members and 1 Guest are viewing this topic. Read 2864 times.
zydeco
HDMI Audio
« on: 11 May 2013, 01:43 pm »
I'm after a solution for audio from computer to a Smyth Realiser which uses HDMI as it's digital input. My reading is that the HDMI i2S output of the Off-Ramp won't work in this application as it's tailored to i2S not HDMI. Is this correct? And, if so, then are you aware of any other h/w that is optimised for getting audio out within the constraints of a HDMI?
Cheers
Zydeco
audioengr
Re: HDMI Audio
« Reply #1 on: 11 May 2013, 06:13 pm »
Cheers
Zydeco
The OR5 will not output HDMI signals, only I2S.  You might try googling USB to HDMI converter.  I think there are some out there, although not great quality.
Steve N.
