0 Members and 1 Guest are viewing this topic. Read 9564 times.
Yes, single driver designs are special (coherent, imaging, don't sound like "hi-fi", active by default - dynamic/amazing bass considering, emphasize the heart of the music - midrange).My 30 - 20,000 Hz Fostex F200A drivers don't peak, but aren't cheap (currently about $450 USD each before i had Bud Puvine treat them). So I don't suffer lack of frequency range, thin/forward sound, or output (they're rated 90 dB/w/m efficient and to handle 80 watt - 19 dB of gain). IMO a good speaker (especially single driver designs) require a good driver. Amazes me the effort/money some put into cabinets/veneers/finishes and invest 5% of the price into the working guts. And as a "speaker guy" it amazes me of the money invested in the rest of the audio chain just to use some dopey drivers. Not trying to be an elitist (I'm cheap, trying to assemble a 2nd system for well under $1000).Have you tried forms of EQ (circuit, electronic equalizer, software equalizer)?Note that many extended range speakers have zobel/baffle step circuits added, so why not provide some help?
Buddy, you're right about the F200A being too much for SET. Tried a 2 and 6 wpc tubes and they puked. But my 7 wpc Class-T did pretty well (but 40 watt chip monoblocks did better - turned polite dinner guest into NFL linebacker in a tux). I believe having plenty of horsepower to provide a commanding grip on the speaker (for improved control for better detail and imaging).
JLM - did you ever try a larger SET on the F200As - something like an 845 or 211?Just curious. The larger SETs can also get kinda pricy.
Omega's new RS5 driver is also pretty close to full range, mid 40 Hz range to 20kHz, and without any peaks. It's 94-95 dB efficient and is a good match for my EL34 SET amp, at around 5.5 watts. Price is ridiculously low for the performance you get. But like any speaker, it's a compromise... single drivers just can't deliver lots of mid bass impact and high SPL levels. For me, it's a good compromise as I don't listen at very high SPLs, but if your priority is to recreate a rock concert a single driver isn't a good choice.
