0 Members and 1 Guest are viewing this topic. Read 3284 times.
The big "wall of sound" has been replaced (except by the dipole fans) with precise (more accurate) imaging.
Hi JLM,Dipoles can (and do) exhibit as "precise" (aka, pinpoint spatial perceived location) imaging, as other formats, with the usual caveats about specific designs, placement, i.e., not too close to boundaries, etc, etc.And what makes this "more accurate"? More "accurate", to what?cheers,AJ
Most speakers of that era and price range one would simply replace with one of the newer models out there, right now that would be the Pioneer BR22 getting rave reviews on another thread. http://www.audiocircle.com/index.php?topic=113182.0 However AR holds a special place in the hearts of devotees and the AR14 is a worthy model to spend some time with. The problem is that they made them for a long time and made running changes in the tweeter and possibly the woofer. I think they started out using the venerable Peerless KO10DT silk dome, but changed that at some point. The thing being you need to find out which variety you have. Also explaining what problems you are having would help.
Didn't mean to discourage from following the vintage dream, I never did the AR thing. After not keeping up with audio/stereo for a few years it was a shock to me to find out how tastes had changed and took me some time to adjust.
Thanks for the question AJ and sorry for pulling this thread off topic.
Hi (Again) JLM and all Audio Circle members.More (BIG) changes in the audio and video are to come and I don't really like it.I am more or less an old fashion guy, I don't like the speed at which that changes happens.Guy 13
