rattling in 12" woofers in V2
0 Members and 1 Guest are viewing this topic. Read 5523 times.
mikeeastman
Re: rattling in 12" woofers in V2
« Reply #20 on: 3 May 2013, 03:11 pm »
I have a pair of SA-1 amps. One is NIB and the other has about 100 hrs on it, I been using it to power a temporary sub in my bedroom system which I'm about to replace. PM me if your interested.
   Mike
Danny Richie
« Reply #21 on: 6 May 2013, 02:30 pm »
Danny, would you suggest going with a used pair of SA-1 or these?  Have you have any excessive reports of bad SA-1 amps?
If you can find some used ones that would be a good find.
I had some go bad mostly from power supply caps, but not too many.
kp93300
Re: SA! power supply caps failure
« Reply #22 on: 8 May 2013, 08:58 am »
Hi  Danny,
Is it difficult to replace these power supply caps?  What are the values of these caps and how many hours do you expect to use before failure?
What are the symptoms of power supply caps failure?
Are there difficult to source parts used  in the SA1 amp ?
It is much cheaper to repair it than replacing for me.
 thanks  for the V2 and I am still enjoying it every day  :thumb:
regards
kp93300
Danny Richie
« Reply #23 on: 8 May 2013, 02:42 pm »
I sent the ones that had this problem to my good friend Charlie Cocci for repairs.
