0 Members and 1 Guest are viewing this topic. Read 11065 times.
For serious audiophiles JPLAY also supports a StreamerMode (setup with two PCs connected via LAN) with dedicated ‘Audio PC’ fully optimised for music transport.Note that in StreamerMode all settings in JPLAY settings utility and advanced settings in regedit or jplay.settings txt file should be adjusted on Control PC.Setup is the same: Install JPLAY on both PCs and configure the host player as explained above on ‘Control PC’. Next open JPLAYSettings utility and click on the button next to Audio PC until you see ‘Search my LAN for JPLAY’: click ‘OK’ to initiate search. If both PCs are on same LAN you should see a message ‘Found JPLAY on 1 computer’. Click OK, reopen JPLAYSettings and you should be able to select your AudioPC and change settings from Control PC. If ‘Search my LAN for JPLAY’ does _not_ find a running JPLAY instance on network you may have a firewall or your LAN settings may need to be entered manually: Please see ‘Network troubleshooting’ for further information. Note you don’t need to have any software on AudioPC apart from Windows and JPLAY: Players like JRiver, foobar2000 or any other ASIO capable player run on Control PC so also all CPU activity they create (loading, decompressing, DSP etc) is completely isolated from Audio PC which sees only music bytes coming via network. Both Wired and WiFi connections are supported although wired Ethernet is usually more reliable especially if you live in an apartment and have strong interference from multiple WiFi spots.
The message pops up when trying to install Sonore exD USB drivers that haven't been "signed". Windows 8 Pro 64 bit enforces code signing more rigorously than the 32 bit version. To get around this error and install the unsigned USB drivers for your DAC follow these instructions.Move your mouse to the upper or lower right corner of the screen. When the Charms menu appears click on the Gear icon, usually the bottom icon. On the following little screen select More PC Settings. After than a screen with several options on the left will appear. Select General on the left menu. Scroll to the bottom on the right and select Restart Now under Advanced Startup. Your PC will appear to restart then popup another menu with options. Select Troubleshoot, then Advanced Options, then Windows Startup Settings, then Restart. Once the PC restarts select the option (number 7) that says Disable Driver Signature Enforcement. When Windows boots you'll be able to install the USB drivers for your USB DAC. Restarting after than will return the PC to its normal code enforcement policy.When you run the Setup for the USB drivers, right click, go to Permissions, then go to the Compatibility tab, then select Run Compatibility Mode: Windows 7, then select Run As Administrator.The USB drivers will install. Then you reboot. Then you play music....
