Anyone tri-amping their speakers with their AKSAs?
0 Members and 1 Guest are viewing this topic. Read 6875 times.
kyrill
« Reply #20 on: 27 Jul 2004, 08:26 am »
hi Andyr
Probably the silver sheet works as a shield against RFI unless "pyramid powers" do their work here  :wink:
I hope the tubes can still loose their warmth enough.
My GK-1 is not build yet but I was thinking of bringing the tubes inside the wooden box, which is easier to shield. Then I have a cooling issue as well. So I will make little holes for air ventilation thru the shield. A Faraday Cage may have little spaces inbetween its nodes.
Try making pyramids of metal(silver)  sheets with some little punctures to air the heat out and let us know.  Since you are walking the path of the absolute I would certainly use Herbies tube dampers. They will make a big difference even in power amps. I will order them certainly, as soon as I start building
kyrill
« Reply #21 on: 27 Jul 2004, 08:27 am »
hi Andyr
Try making pyramids of metal(silver)  sheets with some little punctures to air the heat out and let us know if you hear a diference.  Since you are walking the path of the absolute I would certainly use Herbies tube dampers. They will make a big difference even in power amps. I will order them certainly, as soon as I start building
andyr
« Reply #22 on: 27 Jul 2004, 10:31 am »
Quote from: kyrill
hi Andyr
Since you are walking the path of the absolute I would certainly use Herbies tube dampers ...
Hi, Kyrill,
Actually, I do have a pair of the Herbie tube dampers - they arrived a week or so ago.
Can't say I have noticed much difference with or without them - but I am a bit of a "lazy listener" ... I rapidly get sick of trialling 'A' against 'B' on my own!
Pinging Melbourne GK-1 owners .... anyone like me to bring them round to listen on your GK-1??
Andy
