0 Members and 1 Guest are viewing this topic. Read 9556 times.
ok i see what your problem is, too hot upper hand. Are you sure is the raal and not the acutton. Can you discribe what you are having problem?
I don't care much for the foam pads I need to put on the RAAL tweeters. I know this seems like a trivial complaint ...I understand that a different model of the RAAL tweeter doesn't need the foam pads. Is it fairly straight forward to get the different tweeters and substitute in place? Do any other changes need to take place to accomodate the different tweeter?Alternatively, are there more low profile pads that can be substituted?Wilson
The 70-10 raal doesnt need pads to sound good unless you listen them straight with no crossovers. With the pads, you can tailor the top end roll off. Wonder why the 70-20 dont come with pads.
Due to the different geometry of the 70-20XR, the rising response is not a problem. The 140-15 and 70-10 are both narrow aspect ribbons that will exhibit the rising response. The pads bring that under control, as well as help to improve the vertical off axis response.
I don't have a problem, I just put on the foam pads because I thought they were important and necessary. I just took the pads off and it seems pretty good. A bit hotter, but it could be my imagination ...
The foam pads are used to control the vertical dispersion and flatten out the upper end response. A tweeter change isn't possible because the crossover would need to be changed. Lower profile pads aren't available; however, you can remove the pads if desired though it will create a rising response from about 7K on up. Depending on your listening height and personal preference of treble balance that might be acceptable.
tRick, are you refering the different vertical off axis response from 5k to 10k on your on your tempesta site, depending on +/-? Or are you refering the particular 5.5 k-8k horizontal axis bump?I know therer is a rising response from a raw 70-10, but im not clear what rising response you are refering on the tempesta?
Rick, how many "teeth" should the foam pads cover on the top and bottom? I cover 5 on top and bottom and there are 7 that show in between. Not sure if that's right or not, I don't remember why I chose it.
What I'm saying is the crossover was designed for flat response with the pads in place. If the pads are removed there's a rise in the response starting about 7K going up to 20K.
Sorry Rick, i undertand what you are saying. What im confused is, i dont see any rising response you are refering in any of your tempesta graph, horizontal or vertical. Were the measurement taken with the pads on? Sorry for the question, im just confused.
