0 Members and 1 Guest are viewing this topic. Read 5254 times.
I think that article is actually a good argument for not owning a sub in the first place. Those lowest of low frequencies that we think we should be hearing may not be on the recording anyway.
Think about it. They're high passing the low end to clean up the mud in a jam session or a gig. Don't you think they might do the same in a recording studio too? I personally think we own lots of albums with nothing existing below 30 or 40 Hz.
This doesn't mean we don't have great bass or its not worth persuing. It just means that bass needs to be limited and controlled for better balance. A subwoofer might be the least thing you need.
This is hopefully a good topic and was prompted by reading the spec's on a sub wherein it had a fixed high pass of 100hz, but an adjustable low pass between 50-180hz and recommended at setting of 80hz.Wouldn't that create a situation where there was no signal between 80-100hz? Jim
I think you're misinterpreting the specs for that subwoofer(amp.) The fixed 100hz high-pass is no doubt for the feedthrough to the main speakers and not applied to the subwoofer. The adjustable low-pass is for the subwoofer and not applied to the main speakers.Some subwoofer amps provide a high-pass for the subwoofer as well......but it would most likely be at a frequency considerably below 100hz.Cheers,Dave.
What does the number on the crossover means? Can it be interpret as the roll of point?
That depends on the slope for the fixed 100 hz. Shallow roll like 6 db will be down 50hz, consideting room gains, it may not be a big deal where you cross your sub.
The x/o setting on most subs is the low pass roll off to the subs. Where I got miffed was that some or maybe many employ a fixed high pass filter.Jim
