LampizatOr Generation 4/Level 4... Now we're talking!
wisnon
Re: LampizatOr Generation 4/Level 4... Now we're talking!
« Reply #280 on: 10 Dec 2013, 10:10 pm »
Apology accepted.
wisnon
« Reply #281 on: 10 Dec 2013, 10:11 pm »
Good for you Ted.  I wish i COULD go.  I believe Lucas will be there.  A PCM/DSD L7 and a PCM only Big6 will be on deck.....
Me too…failing that …Atlanta or Hong Kong!
jtwrace
    • TIPP YouTube Channel
« Reply #282 on: 10 Dec 2013, 10:11 pm »
No apology needed.
rockadanny
« Reply #283 on: 11 Dec 2013, 02:50 pm »
Atlanta? Something happening audio-wise in the ATL?  :scratch:
setamp
« Reply #284 on: 11 Dec 2013, 03:30 pm »
My level 4 is balanced.  It has 4 copper Jensen caps and 4 ecc40's as well as a tube rectifier.  The dac gets hot but I use a quiet 120mm computer fan connected to a motorcycle battery to keep it cool.
Wisnon, I am very interested in your comments. Keep them coming. If someone doesn't like the positive or negative feedback from actual experience then they should stop reading this thread.
I assume you had you DAC made with a balanced topology from the beginning?  I wonder if my sided-ended 4/4.5 can be made balanced. I will contact Lukasz about doing that in the future since my pre amp is balanced.
Did you experience a big change from 100 hours to 500?
rollo
  • Rollo Audio Consulting -
« Reply #285 on: 11 Dec 2013, 04:23 pm »
My Dac? I am not the Lampizator and not even in the Audio business. I work in Pharma.
 Sorry my brain fart. Wrong guy.
charles
wisnon
« Reply #286 on: 11 Dec 2013, 04:52 pm »
Yes a Lampi vs Phasure Dac get-together.
rockadanny
« Reply #287 on: 11 Dec 2013, 08:49 pm »
winson - OK thanks.
So, is this at a private home, or club meeting, or dealer showroom meet, or official event of some sort?
If not private, who, what, when, where? (Do not mean to barge in if private - not my intent.)
wisnon
« Reply #288 on: 11 Dec 2013, 10:40 pm »
Dont have the details. Some guys over at Comp Audiophile are arrangging it. Look at the latest Phasure thread there. GearDaddy know more than I do.
rockadanny
« Reply #289 on: 11 Dec 2013, 11:50 pm »
OK. Thank you wisnon.  :thumb:
dminches
« Reply #290 on: 12 Dec 2013, 12:45 am »
I am assuming that there are some others who have the PCM + DSD G4/L4 DACs. Can you tell me if you have to depress the front button to play DSD files?  I thought that I had to but I only get sound when it is in the out position, the same as for PCM.
dminches
« Reply #291 on: 12 Dec 2013, 03:03 am »
Update on this. With the help of Ted B I now have DSD going to my Lampi and it works as designed. Once this is truly broken in I will be able to compare DSD and PCM from ripped SACDs.
this_is_vv
« Reply #292 on: 12 Dec 2013, 06:56 am »
Anyone in Orange County ca have this would love to demo this product if can before spending so much money on it
dminches
« Reply #293 on: 15 Dec 2013, 11:25 pm »
Does the Lampi DAC via USB require both data and power or can one use a cable that only carries data?
parisphoto
« Reply #294 on: 15 Dec 2013, 11:53 pm »
I posed that question to Lukasz, and his reply was :
"USB is totally self powered. No connection to PC power at all. Even galvanic separation exists."
dminches
« Reply #295 on: 16 Dec 2013, 12:02 am »
It seems like most USB cables carry both while many DACs don't require power.
parisphoto
« Reply #296 on: 16 Dec 2013, 12:05 am »
There are some cables that are data only.
http://revelationaudiolabs.com/cables-digital/#USB
Never tried it, so I can't comment.
dminches
« Reply #297 on: 16 Dec 2013, 12:12 am »
Interestingly enough, I own one of them and it didn't seem to work. I will have to try it again.
parisphoto
« Reply #298 on: 16 Dec 2013, 12:26 am »
Lukasz was referring to a L4/G4 DAC.
Perhaps the DSD DAC is different.
dminches
« Reply #299 on: 16 Dec 2013, 12:31 am »
I have a L4.5/G4 with DSD but I was trying with PCM.
