Enclosure shape vs volume
Oscillate
« on: 14 Apr 2013, 03:23 pm »
This question is in regards to the shape of the enclosing box for a sealed
subwoofer alignment... As long as the enclosure's internal volume is correct,
does it actually matter what shape that volume occupies?
I ask because I recall your stating somewhere that having more 'depth' behind
the driver affects the response /voicing of a cone driver in a beneficial way?
Does following the Golden Ratio for a rectanglar enclosure yield any benefits?
After having gone back & forth on different alignments for years, I'm thinking
a sealed subwoofer that is tall, somewhat wide and rather shallow may offer the
most flexibility in placement options.
bdp24
Re: Enclosure shape vs volume
« Reply #1 on: 14 Apr 2013, 05:08 pm »
I'm no acoustical or mechanical engineer, but my amateur view on this subject is:
1- The smaller the baffle, the better. Less flexing of unsupported wood, and the resulting resonance.
2- The lower the center of gravity of the cabinet, the better. Less "rocking" of the cabinet in response to the cone's movement.
3- For the same reason as #2, a short, deep cabinet is more stable than a tall, shallow one.
As for Golden Ratio, etc......at subwoofer frequencies, those issues don't matter.
Danny Richie
« Reply #2 on: 14 Apr 2013, 05:42 pm »
For a mid-range or mid-bass driver, yes. For a sub-woofer, no.
