We are playing with the Pioneer SW-8MK2 woofer
0 Members and 1 Guest are viewing this topic. Read 40102 times.
OzarkTom
Re: We are playing with the Pioneer SW-8MK2 woofer
« Reply #20 on: 2 Jul 2013, 04:54 am »
Amazon now has this sub for $99.99 and free shipping.
http://www.amazon.com/Pioneer-SW-8MK2-Designed-100-Watt-Subwoofer/dp/B008NCD2PC
Ericus Rex
« Reply #21 on: 18 Aug 2013, 02:18 pm »
OzarkTom
« Reply #22 on: 6 Sep 2013, 03:23 am »
Amazon now has it again for $99.99 and free shipping.
http://www.amazon.com/gp/product/B008NCD2PC/ref=pe_54710_32349660_email_1p_0_ti
macnoob
« Reply #23 on: 13 Aug 2014, 01:18 pm »
Just picked one up for $79.95 plus free ship at Amazon.
starkiller
Work ok with Scandyna Micropod SE's?
« Reply #24 on: 13 Aug 2014, 07:04 pm »
Anyone have thoughts on how well this sub might mate up with a pair of Scandyna Micropod SE's that I would like to use as a desktop system?  I want to try and take the room out of my listening equation :)
« Reply #25 on: 13 Aug 2014, 09:25 pm »
Those Micropods appear hard to drive with low impedance and low efficiency (4 ohm load, 86 dB/w/m).  They'd need a stout/stable power supply, yet hard to imagine that they could handle the rated 100 watts with a 3 inch mid/woofer (similarly sized powered speakers have 15 - 20 wpc amps).
Adding bass will cause more room interaction not less (but a sub can be moved, dialed up/down, and adjust for phase).  Recommend trying the speakers without a sub to start with as 60 Hz response goes a long way towards providing satisfying sound on a desktop (way different than at a huge showroom).  Keep in mind that subs can easily overwhelm tight/small spaces and sound very disconnected from speakers sitting on your desktop.
Have you considered Audioengine A2+ powered speakers (with DAC for $250/pair) or PSB Alpha 1 powered speakers ($300/pair that Paul Barton uses at his desk)?  By the way, both have connections for subwoofers.
starkiller
« Reply #26 on: 13 Aug 2014, 09:32 pm »
Yeah, have tried them and they do need a sub.  Vastly different sound then the Bach Classics by Vienna Acoustics that I had been using :)  Tis true about the sub, it CAN be moved, the Bach's can't :)
wushuliu
« Reply #27 on: 19 Dec 2014, 05:29 am »
Recently grabbed 2 for $64 ea. on Amazon. Anyone who uses Google Chrome get Camel, it's a price tracker that will notify of any item on amazon that you look at; select the camel icon, put in your price parameters and voila you'll know as soon as the price drops to what you want.
srb
« Reply #28 on: 19 Dec 2014, 05:46 am »
The Camelizer is also available as an extension for Mozilla Firefox.
