please recommend cd tranport for my bda-1
0 Members and 1 Guest are viewing this topic. Read 1369 times.
BAJ55
« on: 5 Apr 2013, 12:09 am »
I am shopping for a cd transport/cd player to feed my BDA-1 dac. I have a small budget of
$600-$1000. Used is fine and probably the way to go. Anyone have any ideas for me?
Thanks In Advance.
BAJ55
Mag
Re: please recommend cd tranport for my bda-1
« Reply #1 on: 5 Apr 2013, 12:40 am »
I would go with a computer with a good soundcard. Use the USB output and I recommend VLC media player which you can download. By using the computer you can control the wave strength in the Master Volume Control.
I also use a Sony Blu-ray BDP-S185 $70.00 CDN which sounds as good to me as using the computer.
The source IMO will be the sound characteristic you hear. So if you're looking for a warm sounding player you'll have to try and find one that suits you're liking. My Sony NS9100ES is warm sounding. 8)
Phil A
« Reply #2 on: 5 Apr 2013, 01:07 am »
One of my favorites that is not terrible expensive when I had my BDA-1 and I still use it is a Marantz DV9600.  For a bit I had it in a secondary system and brought it back for use as a CD transport.  I might even know someone who still has one.  If CDs were my going to be my main source going forward, I'd look to get another one.  I use a music server with a DSD DAC now.
Quiet Earth
« Reply #3 on: 5 Apr 2013, 01:34 am »
If I had a $1000 limit for a new CD transport I would roll the dice on a new Musical Fidelity M1 CDT. I have never heard one, but for the dough it looks to be well laid out.
If used and under 3 years old, an Audio Note CDT Zero.
No on the computer.  :nono:
larevoj
« Reply #4 on: 5 Apr 2013, 02:20 am »
Yes, I too would recommend Audio Note...you won't go wrong with Philips PRO2 transport and tubes. Another good company with this mix is from Audio Research Reference transport.
Quiet Earth
« Reply #5 on: 5 Apr 2013, 02:38 pm »
larevoj,
I don't think you can get a Phillips CDpro2 based transport for under $1000 without building it yourself. The mechanism itself is almost $400.
werd
« Reply #6 on: 5 Apr 2013, 06:12 pm »
Buy my Sony S7700 turbo modded by Empirical audio. i have it for sale and it works excellent with the bda. Thats what i used before i bought the bdp. Its up for sale on CAM pretty cheap.
larevoj
« Reply #7 on: 6 Apr 2013, 01:25 am »
larevoj,
Yup, you can and there are DIY kits available.
However, I am not sure how good the diy kit will sound...
