0 Members and 1 Guest are viewing this topic. Read 50247 times.
You're missing (or not understanding) the points that are being made. Not only by me, but Pete, Scotty, and Quiet Earth as well. Anyways, the 10k resistor comment was a retort to your comment that "you can't put anything across the speaker terminals without its affecting the sound." I think you missed the point there too, which was....that a 10k resistor will not affect the sound. It's completely innocuous in that position.Cheers,Dave.
Pete, any idea why dome tweeters sound better when their impedance curve is flattened.Scotty
If the tweeter is connected directly to the solid state amp, with no XO components in between, I'd say they sound better due to the power of suggestion.
I give Scotty more credit than that. It's certainly possible that if amplifier output impedance is significant and the Zobel component values are causing a change to the voltage function applied to the driver there would be an audible difference.Neo,You appear to be dug in on this. A Zobel will not always change the sound of a driver. It may, it may not.....depending upon the power amp, the Zobel component values, and the transducer characteristics.Cheers,Dave.
A Zobel is a shunting network and not a crossover filter. I've seen a number of full-range systems that employ impedance leveling devices.That shouldn't violate the "fullrange" mandate/requirement, should it? Dave.
You appear to view everything as black or white. I'm more pragmatic....it comes from years of experience. Why is it so difficult to grasp the concept that a Zobel might not change the sound of a driver?Here's an example.....what if I attach a 10 ohm / 0.33uF Zobel across the speaker leads to my dome tweeter? (My amplifier has really low output impedance.) That will terminate the speaker leads with 10 ohms above the audio band, but should not change the drive level to the tweeter within the audio band.Do you think removing/attaching that Zobel will change the audible sound of said tweeter?Cheers,Dave.
I already posted about possible benefits in the ultrasonic region. If that network is actually accomplishing anything, removing it could change the sound of the tweeter. I was specifically talking about conventional zobels designed to counter rising impedance of the driver, in bandwidth, not Scanspeak speaker wire networks.If you think a conventional zobel has no affect, why use it in the first place? If it allows a tube amplifier to successfully drive the speaker then at the least it's changing the sound of the speaker with that amp. This seems like semantics. I don't think you can use a zobel to limit impedance in a crossover region without changing the sound of the driver.Why is it so difficult for you to grasp the concept that someone might have a different opinion than yours, based on experience?neo
But adding a zobel to a driver that is directly connected to the amplifier output will have no effect on the output of the driver if the amplifier has a low output impedance to start with, which is case here using solid state amplification.
You're saying if I hook up a zobel to an 8" full range driver which is connected directly to an amplifier, it will sound the same as w/o the zobel?I find this hard to believe.neo
