0 Members and 1 Guest are viewing this topic. Read 50085 times.
Is anyone aware of any downside to using a Zobel network to flatten out the effective impedance seen by the amp?
When one insert a inductor, resistence, capacitor or any eletric part between the amp and the speaker driver the musical harmonics gone, they are transformed in heat.The musical harmonics time integrity are the called fullrange effect.The less bad is the inductor, the worst is the capacitor.
Seems it use a capacitor or resistence.
I've never heard a fullrange speaker that can compete with a well designed two-way for realism, smoothness of response, and distortion. It's just physics . . .
I don't get it. I find fullrange speakers consistently downplayed by a majority of people I've come across, but loved by a very few. What are they hearing as superior that technically, they shouldn't be?
I don't need a Zobel at all at the moment, as I'm putting together an active system powered by very stable SS amps.
if the designer felt that it's impedance flattening benefits were justified to begin with, for a given combination of speaker, cable and amp
The question was not intended as a platform to debate single driver speakers vs multi-driver speakers. Nor was it intended to argue whether a Zobel was needed in a given design or not. It was intended to determine what penalties a Zobel might impose if the designer felt that it's impedance flattening benefits were justified to begin with, for a given combination of speaker, cable and amp.Any further insights would be appreciated. Thanks.
The Zobel network will flatten the impedance of the speaker, but at the cost of power dissipation, and a slightly lower than expected overall impedance. Naturally, the power dissipated by the resistor is turned into heat, not sound, reducing effective efficiency. The lower impedance may cause some stress to certain amplifiers, but most should be able to cope with the slight extra loading. It must be understood from the outset that the flattened impedance curve does not make the speaker perform any better at the higher frequencies - the sole purpose of the Zobel network is to ensure that the impedance presented to the crossover network remains essentially constant over the frequency range where variations would cause an unacceptable frequency response variation in the filter network. The determination of the required values for the Zobel network is most easily done by measurement and experimentation.Once determined, the Zobel network must be treated as part of the loudspeaker. All measurements or calculations for the crossover network must include the Zobel network and loudspeaker driver combined. If correctly done, the combination of the two will give an acceptably flat and very usable impedance across the entire crossover region. This will result in a crossover filter with the minimum error possible.
The power absorbed by the resistor might present an even impedance to the amp, but will also absorb power that would have gone to the driver.
