The hum is coming from the speakers. Before I replaced the output tube, I noticed the hum when I bent over to turn off the amp. I did not measure the distance the hum was audible from the speaker, but I conjecture it would have been audible from about six or seven feet. The speaker drivers were actually vibrating when I touched them. I replaced the tube, and there is still a hum that is audible from maybe seven or eight inches, but it used to not be there. I've not changed anything in the system. I have an Adcom 555 amp that I use for home theater, and I hooked up the Adcom amp, and there is no hum. I made sure my pre-amp was off, and it was, and then I switched the pre-amp from the phono output to the line output, and still there is hum.
I've never replaced the either of the driver tubes. How do you know when they go bad?
