0 Members and 1 Guest are viewing this topic. Read 73326 times.
Tom,I've followed your first tour "dirty dozen" and eventually bought the MG3 for my Klipsch forte ii. I recently called Jan (didn't expect to talk to him directly) and will be sending my amp in for a MK II capacitor upgrade. I do have a couple of questions: 1) which 12v batter are you using? In your previous thread you listed 3 but they all had different ah's; 2) i'm on Los Angeles and do you think any of the guys listed wouldn't mind having an open session for other to come by and listen? Thanks for your time,Javier
What are the most notable differences in sound Ozarktom? Sounds like the upgrade is a no-brainer but would still like to know the difference.
Hi Tom,I too would really like to be on the tour. I'm in the Seattle area and tried to buy the amp Freo-1 was selling.Thanks,Greg
I have logged-in 70 hrs. of run time on the new MKII mod of my TBI Millenia MG3 this past week, & finally was able to get in some serious listening today other than just low level background music, tv/ movies, etc..This is an extreme improvement over the MKI mod. The MKII version has absolute killer inner detail, better musical accuracy, deeper soundstage & is smooth as silk.In my system w/ a recently added Amperex 6922 PQ white label gold pin tube in my Grant Fidelity TubeDAC-11 which also servs as a preamp:Much more refinement; as Mister Pig previously stated, there is a finer subtlety & nuance to the music.Main vocalist is slightly more forward, but rock solid. Instruments are further back with better separation.I listened to a lot of familiar songs, many different genres, 16 bit/ 24 bit hi-rez & they all sounded clearly better. This is one sweet little amp & these latest improvements take it up several notches in my book.Note that I only listened with the stock upgraded AC power supply. I have a 2-12v x 5 amp battery kit incl. a 24v trickle smart charger that I auditioned in the MKI & preferred the AC ps. Maybe later I will try a single 12v battery, but right now I am loving the current set-up w/ my GR Research N3 91 dB speakers, Mac mini dedicated music server & Oppo BDP-83SE Blu-ray player.
That's great news. Nothing like a report from the field to help put things in perspective.
