TBI Millenia MG3 Mk II amp tour-Round Two
0 Members and 2 Guests are viewing this topic. Read 73332 times.
OzarkTom
Re: TBI Millenia MG3 Mk II amp tour-Round Two
« Reply #140 on: 10 Jul 2013, 03:39 am »
So, which would be best to get if just powering a single TBI--3 amp version or 5 amp version?
Randy
There is also a 3 amp version on Amazon for $105 and free shipping. Randy was probably questioning the two choices.
http://www.amazon.com/Mastech-Single-Output-Power-Supply-HY3003D/dp/B004ISQ270/ref=sr_1_4?s=industrial&ie=UTF8&qid=1373427479&sr=1-4
rodge827
« Reply #141 on: 10 Jul 2013, 03:48 am »
Tom,
I used some simple cheap 18g wire from Rat Shack and picked up a DC plug to match the one on my Dual Core.
Looks like a pair of banana jacks would be needed for the HY3005D.
http://www.radioshack.com/product/index.jsp?productId=3807941&clickid=prod_cs
http://www.radioshack.com/product/index.jsp?productId=3780267&clickid=prod_cs
Chris
OzarkTom
« Reply #142 on: 10 Jul 2013, 03:49 am »
Sheesh, and you can also buy this by Dr. Meter at newegg.com for $115.99 and free shipping. I read in an Amazon review that this supply went by three different names. It looks like I found all three.
http://www.newegg.com/Product/Product.aspx?Item=9SIA1PK0JM2392
OzarkTom
« Reply #143 on: 10 Jul 2013, 03:53 am »
Tom,
Chris
These bananas were on Amazon with alligator clips for $5.18. I could always cut the clips off and rewire with a DC plug.
http://www.amazon.com/gp/product/B0002JJU1O/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
rodge827
« Reply #144 on: 10 Jul 2013, 03:58 am »
Yes, should work well that way.  :thumb:
OzarkTom
« Reply #145 on: 10 Jul 2013, 04:07 am »
And Chris, I found my DC plug with easy screw in terminals for $2.79.
http://www.bixnet.com/cnt525m.html
DaveC113
  • ZenWaveAudio.com
« Reply #146 on: 10 Jul 2013, 04:23 am »
In the first tour thread, I said that a good linear ps would equal or better a battery a few times.  :green:
I got a used Power One on ebay for about $30 for my Trends T-amp, it comes in a kind of half-enclosure meant to be mounted in another chassis. It was just as good as an Optima yellow top battery with a good sized capacitor bank of both electrolytics and film caps. After that, I have not given much consideration to using batteries. Now even switching supplies are getting to the point where they can be great performers.
sugbob21
« Reply #147 on: 10 Jul 2013, 12:56 pm »
Hi....i have also finally tried my King Rex PSU over the weekend and heard a noticable difference over the standard power supply. i have been running 2 of them in mono with the standard and prefer the one connected to the KingRex.  i am using the second one now as a headphone amp after ordering the headphone adapter from TBI.  Dont know how much use i am going to get out of that though as i enjoy listening through speakers much more.  i wish i could hook both up throught the King Rex but i dont think thats possible. the dual linear power supply would be the only other option but i cant figure out how to connect the power supply to the amps.  What wires and connections do i need ?     if its too complictaed for me will just keep the one amp into the KingRex.
rodge827
« Reply #148 on: 10 Jul 2013, 01:28 pm »
Niiice  :thumb:
I just crimped the 18g to the wire extensions, but I like the screw terminals.
Which King Rex PS are you using original or mk2?
sugbob21
« Reply #149 on: 10 Jul 2013, 01:30 pm »
Its about 3 yrs old.     Model just says PSU. So i think its the original.
sugbob21
« Reply #150 on: 10 Jul 2013, 05:04 pm »
if i am following this correctly ...the power supply has red green and black outputs. are these fiitted with bananas and then a single DC plug into the Millenium ?  I dont know for sure if i am going to try but just in case i would like to know how this all connects.  Right now i am enjoying the King Rex improvements.  The power supply would enable me to go back to using both amps againif i get the dual power supply.
rodge827
« Reply #151 on: 10 Jul 2013, 05:22 pm »
Yep you got it  :thumb:
Not sure if you need to use the Green (ground) output, a look into the owners manual would answer that.
OzarkTom
« Reply #152 on: 10 Jul 2013, 05:37 pm »
For about 200 dollars you can get a one of these power supply that has three outputs, two are variable and one is fixed. That one weighs 25 pounds.
http://www.amazon.com/Mastech-HY3005F-3Triple-Linear-Power-Supply/dp/B004ISD7T6/ref=sr_1_5?s=industrial&ie=UTF8&qid=1373477749&sr=1-5
sugbob21
« Reply #153 on: 10 Jul 2013, 06:09 pm »
will check that one out.  thanks.
Freo-1
« Reply #154 on: 19 Jul 2013, 01:42 pm »
What's the latest with the tour?
OzarkTom
« Reply #155 on: 19 Jul 2013, 01:53 pm »
rodge827 should be getting the amp real soon. I am still evaluating this Ten Tec power supply with the TBI on my system. So far, it sounds fantastic.
Freo-1
« Reply #156 on: 19 Jul 2013, 01:55 pm »
Sounds good.  What improvements are noticed?
sugbob21
« Reply #157 on: 19 Jul 2013, 02:14 pm »
I am back to using 2 Millenias with my Dodd tbe buffer and the original power supplies. Using 1 as a headdphone amp was a failed experiment. I received the adapter from Jan but didnt realize i needed  to modify the heaphone connections to fit speaker inputs also. The Kingrex power supply sounded much better but only powered 1 amp unfortunately.  The Mytech dual power supply sounds interesting but dont know how that one performs and its reliability.
OzarkTom
« Reply #158 on: 19 Jul 2013, 02:24 pm »
More open and a fuller sound. It also drives my 84db Zellatons harder than the 12v battery does.
sugbob21
