Small Room - Want Maggies
SteveFord
Re: Small Room - Want Maggies
« Reply #60 on: 30 May 2013, 01:29 am »
You're welcome.
When I bought my old 1.6s the owner had them set up in this really tiny room in a NYC apartment.
They sounded really good and he was driving them with a 60 WPC integrated McIntosh tube amp.
You don't necessarily need Madison Square Garden for them.
josh358
« Reply #61 on: 30 May 2013, 02:10 am »
I think Steve is spot on. I have a 13 x 14 room and while I'd like a larger one, the MMG's sounded great in them and that means the 1.7's will do even better. And if you add a couple of QRD diffusors behind the speakers at the first reflection points, it will make the room larger acoustically.
NIGHTFALL1970
« Reply #62 on: 30 May 2013, 02:31 am »
Go for the 1.7s! :thumb:
jsaliga
  • Vinyl Provocateur
    • The Spinning Record
« Reply #63 on: 31 May 2013, 11:46 am »
Thanks all.  I spoke to the Magnepan dealer here in Connecticut yesterday and they went over the options, costs, and delivery.  I will be placing an order for a pair of 1.7s.
--Jerome
NIGHTFALL1970
« Reply #64 on: 9 Jun 2013, 02:32 pm »
Jerome,
did you ever get your 1.7s?
guest61169
  • Guest
« Reply #65 on: 23 Jun 2013, 01:55 am »
My room is about 12' x 17'.  Usually use a 700 wpc (into 4 ohms) power amp but today swapped that out and inserted my Dennis Had Inspire 5 wpc EL84 single-ended Class A tube amp.  Listening at moderate volume to some Alan Parsons and in this condo, volume is fine...no clipping happening and sounds very nice.   You don't need mega-power if your room is small and volumes not crazy loud.
