Todays Smile
0 Members and 1 Guest are viewing this topic. Read 428329 times.
LesterSleepsIn
  • Occasionally consternated
Re: Todays Smile
« Reply #2300 on: 18 Nov 2019, 01:02 pm »
  • The Demo is Everything!
    • http://www.bryston.com
Re: Todays Smile
« Reply #2301 on: 19 Nov 2019, 02:57 am »
Re: Todays Smile
« Reply #2303 on: 22 Nov 2019, 11:41 am »
Re: Todays Smile
« Reply #2304 on: 22 Nov 2019, 04:06 pm »
I see this happen all the time here, there are several guys in uniform doing nothing, just looking and just one working.
gberger
  • Check 6
Re: Todays Smile
« Reply #2305 on: 22 Nov 2019, 04:27 pm »
It's called Unionized Labor.
charmerci
Re: Todays Smile
« Reply #2306 on: 22 Nov 2019, 05:19 pm »
 :scratch:
The managers are in a labor union???
gberger
  • Check 6
Re: Todays Smile
« Reply #2307 on: 22 Nov 2019, 06:09 pm »
Depends on the trade, the company and the location (country.)
In some places, a ditch-digger becomes an Evacuation Specialist, his boss an Evacuation Leader, and his boss an Evacuation Manager.
Where I live, the crew that collects the trash and recycle stuff are known as Resourse Recovery Specialists.
CanadianMaestro
Re: Todays Smile
« Reply #2308 on: 22 Nov 2019, 06:18 pm »
aka. public sector.
Re: Todays Smile
« Reply #2309 on: 22 Nov 2019, 09:57 pm »
Nice to see this sand and gravel is properly secured.
james
gbaby
Re: Todays Smile
« Reply #2310 on: 22 Nov 2019, 11:50 pm »
The problem with this observation is folks don't stick around to see what the others have to do next after that one man gets out the hole. Laborers don't have a chance with everyone playing arm chair quarterback.  :roll:
noway
Re: Todays Smile
« Reply #2311 on: 23 Nov 2019, 05:11 am »
I don't think being disrespectful/political belongs in a humour thread.  Please read the guidelines:
https://www.audiocircle.com/index.php?action=about;area=posting-guidelines#posting-no-nos
"Defamatory remarks
Do not use this site to make defamatory remarks about people or organisations. Apart from potentially causing damage to this site, it's cheap and nasty behavior. If you say something negative, ensure that it is factual and not speculative."
Shakeydeal
Re: Todays Smile
« Reply #2312 on: 23 Nov 2019, 11:03 am »
So you had nothing to say about the political cartoon on page 115, yet you comment on something so benign as to make yourself look foolish?
Re: Todays Smile
« Reply #2313 on: 23 Nov 2019, 01:07 pm »
Its really too bad that a simple cartoon degenerates into a caustic engagement :scratch:
james
Re: Todays Smile
« Reply #2314 on: 23 Nov 2019, 01:09 pm »
Re: Todays Smile
« Reply #2315 on: 23 Nov 2019, 04:43 pm »
A 10MB harddrive from the 60's
Re: Todays Smile
« Reply #2316 on: 23 Nov 2019, 06:19 pm »
512K ram ca.1982
Silverbullet
Re: Todays Smile
« Reply #2317 on: 23 Nov 2019, 07:17 pm »
Boy these photos bring back memories. I started working in 1965 as a programmer on an IBM1440 mainframe, a full 8K later upgraded to 12K, it had 3 disk drives attached of 1MB each.
gberger
  • Check 6
Re: Todays Smile
« Reply #2318 on: 23 Nov 2019, 07:26 pm »
 Ditto!
And, having to use the 80 column pouch cards.  The cards were cut, then "re-cut" to verify. Also, we had to wire the printer board for the required print-out.
Re: Todays Smile
« Reply #2319 on: 23 Nov 2019, 07:39 pm »
I worked with the smaller 96 columns card in the 1970s when operating a /3 only 32K ram for a couple of years, the console was a continuous paper typewriter, now seems good times.
« Last Edit: 23 Nov 2019, 11:23 pm by FullRangeMan »
