Todays Smile
Saturn94, BCRich1 and 2 Guests are viewing this topic. Read 354255 times.
  • The Demo is Everything!
    • http://www.bryston.com
Re: Todays Smile
« Reply #2160 on: 20 Jun 2019, 11:13 am »
Re: Todays Smile
« Reply #2161 on: 20 Jun 2019, 04:56 pm »
Re: Todays Smile
« Reply #2162 on: 24 Jun 2019, 11:31 am »
WGH
Re: Todays Smile
« Reply #2163 on: 24 Jun 2019, 07:00 pm »
jhm731
Re: Todays Smile
« Reply #2164 on: 27 Jun 2019, 06:09 pm »
JerryM
  • Where's The Bar?
Re: Todays Smile
« Reply #2165 on: 30 Jun 2019, 07:28 pm »
jhm731
Re: Todays Smile
« Reply #2166 on: 30 Jun 2019, 10:18 pm »
mikeeastman
Re: Todays Smile
« Reply #2167 on: 1 Jul 2019, 01:26 am »
Re: Todays Smile
« Reply #2168 on: 2 Jul 2019, 02:35 pm »
jhm731
Re: Todays Smile
« Reply #2169 on: 2 Jul 2019, 05:10 pm »
Re: Todays Smile
« Reply #2170 on: 3 Jul 2019, 01:19 am »
Grit
  • - Garrett
Re: Todays Smile
« Reply #2171 on: 3 Jul 2019, 06:32 am »
 :icon_lol: preach on!
dflee
  • What's this we shit kemosahbee?
Re: Todays Smile
« Reply #2172 on: 3 Jul 2019, 02:47 pm »
Canadian bacon I presume.
gberger
Re: Todays Smile
« Reply #2173 on: 3 Jul 2019, 03:22 pm »
Nah! That's a pile of the cheap stuff
Re: Todays Smile
« Reply #2174 on: 3 Jul 2019, 03:48 pm »
Re: Todays Smile
« Reply #2175 on: 3 Jul 2019, 06:28 pm »
I must be really old cause I failed to understand this one.
WGH
Re: Todays Smile
« Reply #2176 on: 3 Jul 2019, 07:52 pm »
It's the only way to grill when the weather is hot and humid with voracious mosquitoes in waiting.
Re: Todays Smile
« Reply #2177 on: 3 Jul 2019, 08:00 pm »
Thanks bro, I not realise it was a grill :duh:
Re: Todays Smile
« Reply #2178 on: 5 Jul 2019, 09:17 am »
Ellisville, Mississippi, April 12, 2011.
An Ellisville school teacher called the local phone company to report her telephone failed to ring when her friends called - and that on the few occasions, when it did ring, her dog always moaned right before the phone rang.
The telephone repairman proceeded to the scene, curious to see this psychic dog or senile lady. He climbed a telephone pole, hooked in his test set, and dialed the subscriber's house.
The phone didn't ring right away, but then the dog moaned and the telephone began to ring.
Climbing down from the pole, the telephone repairman found:
1 . The dog was tied to the telephone system's ground wire with a steel chain and collar
2. The wire connection to the ground rod was loose.
3. The dog was receiving 90 volts of signaling current when the number was called.
4.. After a couple of jolts, the dog would start moaning and then urinate.
5. The wet ground would complete the circuit, thus causing the phone to ring.
Which demonstrates that some problems CAN be fixed just by pissing and moaning!
Thought you'd like to know.
jhm731
Re: Todays Smile
« Reply #2179 on: 6 Jul 2019, 09:21 pm »
