BRYSTON BOT-1 (Bryston Optical Transport)
brystoned
Re: BRYSTON BOT-1 (Bryston Optical Transport)
« Reply #340 on: 8 Jul 2015, 09:17 am »
james
what manufacturer is the drive in the BOT-1 ?
ed
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #341 on: 8 Jul 2015, 10:12 am »
james
ed
Panasonic
james
brystoned
« Reply #342 on: 8 Jul 2015, 11:06 pm »
thanks james
panasonic drive like this ?
is the front panel with hardware eject button removed before installing in BOT-1 ?
ed
« Reply #343 on: 8 Jul 2015, 11:15 pm »
Do not think so as we do not have to alter it to use it.
James
BrystonFan
« Reply #344 on: 9 Jul 2015, 08:37 pm »
The BOT-1 is now officially on the Bryston site.
Brochure and manual included  :thumb:
Thanks James
srb
« Reply #345 on: 9 Jul 2015, 08:42 pm »
And also now listed on U.S. vendor site Audio Advisor (Expected 7/17/15)
richter250
« Reply #346 on: 9 Jul 2015, 11:46 pm »
Just received my BOT-1 and looking forward to hooking it up and ripping all my CDs into my BDP-2.  The BOT-1 comes with a USB Y cable.  No mention in the manual.  My understanding is that this type of cable is used to provide extra power to a USB device.  Isn't the BOT-1 powered by the wall wart?  Just a little confused.  Thanks.
« Reply #347 on: 9 Jul 2015, 11:48 pm »
Hi
Yes please ignore the USB with the red pigtail end - it is meant to supply more power but with the wall wart not required.
james
richter250
« Reply #348 on: 9 Jul 2015, 11:52 pm »
Thanks James!
mv
« Reply #349 on: 10 Jul 2015, 09:59 am »
Can the BOT rip SACDs, and have the info saved as .dsf files on an internal disk in a BDP-2?
« Reply #350 on: 10 Jul 2015, 10:52 am »
HI
No just CD's at this point.  It is  DVD BluRay drive so we will be adding features in the future but I do not believe Sony allows access to SACD bit streams.
james
Krutsch
« Reply #351 on: 10 Jul 2015, 01:44 pm »
HI
james
This has been mentioned before (i.e. new features); I am very curious what that might entail. SACD will never happen, as you mention above. But even DVD and/or BD ripping is a challenge, from a legal standpoint. Some countries have fair use laws that would allow this, but neither the US nor Canada are one of these countries.
Direct DVD Video/Audio and BD audio playback would be interesting, using the MM UI to control playback, even without a display connected, if you can acquire the chapter titles and present them as a list of tracks, auto-selecting the mandatory 2-channel PCM track required by those formats. I have a BD player and an LCD panel in my head-fi stack just for this purpose and I would love to get rid of it.
Could be very cool if it's done right... anyway, anxious to see what's next with the BOT-1.
rmurray
« Reply #352 on: 10 Jul 2015, 04:24 pm »
   and I would  still prefer a tray loader of some kind :thumb:
« Reply #353 on: 10 Jul 2015, 04:34 pm »
Thanks James
http://www.bryston.com/products/digital_audio/BOT-1.html
james
mv
« Reply #354 on: 10 Jul 2015, 06:19 pm »
what is:
BPS-3 multi-device power supply
that is mentioned at the bottom of the BOT-1 web page?
« Reply #355 on: 10 Jul 2015, 06:23 pm »
what is:
We are thinking of including a separate matching power supply for the BOT
Rod_S
« Reply #356 on: 10 Jul 2015, 07:49 pm »
Very interesting, a perfect matching pair :)
brystoned
« Reply #357 on: 11 Jul 2015, 12:39 am »
james
perhaps you could design brackets similar to the rack ears that mount from underneath the BOT-1, BCU-1, BPS-3 etc to tie 2 or 3 units together ?
just a thought ...  :o
ed
mv
« Reply #358 on: 11 Jul 2015, 04:45 am »
Will this power supply come together with the BOT-1 in the same package?
BTW, will the BOT-1 connect to a BDP-2 via a regular USB cable?
(So that we can try using more expensive cables to see how that will improve teh quality.)
« Reply #359 on: 11 Jul 2015, 11:14 am »
Hi
It will be an optional outboard unit rather than the wallwart which comes with the BOT.  To large to include in the BOT.
Yes it just comes with a standard USB cable so you can certainly experiment with exotic cables if you wish.
james
