Poll
Which amp sounds the best?
A
0 (0%)
B
2 (40%)
C
3 (60%)
D
0 (0%)
Total Members Voted: 5
Voting closed: 3 Jul 2004, 12:12 am
Which amp is the best out of these 4?
0 Members and 1 Guest are viewing this topic. Read 2035 times.
AintJoM0mma
« on: 3 Jul 2004, 12:12 am »
Simple question. Which amp sounds the best?
A) Jolida 1501RC (Hybrid)
B) Jolida 102B With Mods* (Tube)
C) Jolida 301 (Hybrid)
D) Jolida 202A (Tube)
*Mods: This is the newest JD102B that has the transformer cover added for a smart handsome look. We have gone inside and upgraded all the signal path capacitors to audiophile grade pieces. (6 in all) A balance bypass modification is included to avoid running the signal through the cheap chinese switch. Balance is unnecessary on these amps anyway. The chassis is damped and shielded with StarrDamp CS, and the unit comes with 4 KTS iso damp discs for under the feet of the amp. This is for vibration isolation. All the preamp tubes and driver tubes are upgraded to Russian ElectroHarmonix for a more open transparent sound, and the 4 EL84's are also EH of Russia.
Hantra
« Reply #1 on: 3 Jul 2004, 12:40 am »
D) Any Plinius
AintJoM0mma
« Reply #2 on: 3 Jul 2004, 12:50 am »
Yeah well not all of us have $3000 to spend on amps  :roll: .
zybar
« Reply #3 on: 3 Jul 2004, 12:54 am »
Or would spend it on a Plinius... :lol:
Sorry B, couldn't resist.
George
AintJoM0mma
« Reply #4 on: 3 Jul 2004, 01:06 am »
Well vote then.  :D
Hantra
« Reply #5 on: 3 Jul 2004, 01:20 am »
Quote from: zybar
George
I deserved that. . .  :wink:
AintJoM0mma
« Reply #6 on: 3 Jul 2004, 01:35 am »
Nevermind
Marbles
« Reply #7 on: 3 Jul 2004, 04:35 am »
You should really ask your question here:
http://www.audiocircle.com/index.php?board=35
Bill is a Jolida dealer and modder and can answer your questions much better than most of us can.
