Adding a sub in a small roomski.
0 Members and 1 Guest are viewing this topic. Read 8482 times.
neekomax
Re: Adding a sub in a small roomski.
« Reply #20 on: 5 Mar 2013, 07:12 pm »
All of the subs I listed are sealed and not ported...
Yes, but some are too expensive.
DTB300
« Reply #21 on: 5 Mar 2013, 08:03 pm »
it is just like walking into an Audio Store and asking what they have for $600.  You know they will start at $1k...   Always good to know what is out there for your budget and some others for some more $$$
neekomax
« Reply #22 on: 5 Mar 2013, 08:17 pm »
Just throwing it out there... what about getting two of these? Can't tell if they're sealed or ported, though. Seems like a ridiculously low price...
http://www.accessories4less.com/make-a-store/item/MORDCARN9CAL/MORDAUNT-SHORT-Carnival-9-10-100-Watt-Powered-Subwoofer-Calvados/1.html#!more
asliarun
« Reply #23 on: 5 Mar 2013, 10:54 pm »
I haven't heard them myself but Hsu subs have been on my list for a while.
Their VTF series also has an interesting design - they have two ports - and you can leave both open, close one, or close both and make it a sealed sub. The sub is designed to work in all these configurations. The VTF-1 sells for about $460.
http://www.hsuresearch.com/products/vtf-1mk2.html
neekomax
« Reply #24 on: 6 Mar 2013, 02:41 am »
Very interesting... thanks for that!
