0 Members and 1 Guest are viewing this topic. Read 23589 times.
We left off with an example of a stylus/cantilever substitution that didn't work out IMO, but that's a judgement call and could have been evaluated differently. I read a similar description on Agon about a different cart w/ruby upgrade and hyper-detail, and the person loved it. To be honest, I would have kept the 304 and used it with on-the-fly VTA, if it was a better match with my AHT phonopreamp. The 2 top Denon carts have very low output and relatively high inductance/resistance. This inductance interacts with cable/preamp load capacitance and can cause high frequency overload - oscillation or intermodulation distortion in some preamps with extended bandwidth. This is more common than you might think. I read another similar description of the DL-S1 in an evaluation, and a prominent poster on Asylum loads his DL-S1 at 30 ohms, the impedance of the cart. That results in effectively reducing the already extremely low output, in half. In all fairness to Soundsmith, he does really nice work, is extremely knowledgeable and completely honest. I had a couple of long conversations with him and he'll go to great lengths to make sure you understand the considerations and are happy with the results. I'm sure that many more people have good results in upgrading to an exotic stylus/cantilever, than those that have bad results. I've reached the conclusion that this depends on the specific cart and the specific change. Not all carts are created equal. It's your examples of retip/rebuild experiences that will help all of us.neo
One thing to keep in mind & to be aware of is setup. If going with the TOTL replacement from Soundsmith great care should be used while setting up VTA and azimuth. To get the best sound this is a must. These are by no means plug and play. If not setup properly you are truly missing out. Of course this is true with all cartridges but with the precision of Soundsmith's top tier replacement I have found it is even more critical.Jeff
I was hoping we would get more re-tip/rebuild results and opinions from end users.Soundsmith usually recommends staying with the same cantilever if it's an exotic type (boron, sapphire etc) and it's still serviceable. A cartridge is voiced with a particular cantilever material and changing that material may or may not result in improvement. On the other hand you may want to change the sound of your cart. In general, the shorter the cantilever, the less this change will be.I've done a lot of experimenting with AT MM carts - changing cantilever material and tip shapes, trying to get a handle on what does what. It's a little more complicated with MMs, because of capacitance loading combined with frequent use of cantilever resonance to augment amplitude response. More on this later. Any experiences, examples on this subject are welcome.neo
Great thread Neo. I've sent a number of carts (Shelter 501, Grace F-9E's, Signet TK100LC) to Soundsmith for rebuilds (usually level 2 - ruby/LC) and have, in all cases, felt the rebuild provided an upgrade over the stock cantilever and stylus. I didn't have a working cart to start with on the TK100LC (snapped ruby cantilever) but figured the level 2 rebuild would be very close to original state. I also recently sent a Signet TK10ML with a worn stylus to Peter for a retip (not rebuild) of the original boron cantilever with a LC stylus and it sounds gorgeous - probably as close as I could get to the original state (the only difference being LC vs ML). I was a little concerned about the amount of adhesive used for the retip but it doesn't seem to affect the playback any but again I don't have a stock cartridge to compare with.Regarding vintage Signet and AT carts, I've been collecting a few (TK7E and SU, 20SLa and SS, AT 155LC and 160ML, AM40s, etc. and am very interested in learning more from your experiences switching out the various stylus assemblies that are available and will fit these carts. My Signet TK10ML's, TK9LCa and TK100LC are another matter as replacement stylii are virtually non-existent - though there are still a few TKN-22's (beryllium cantilever with elliptical stylus) around.Jack
I did finalize (I think) my VTA on my Virtuoso over the weekend and I was overcompensating for the change in cantilever angle. I believe I have it dialed in pretty good now. The SS rebuild is clearly worth it. I would imagine the Maestro improvements would also be notable, although that cartridge started out with a better stock cantilever than the aluminum one I had on the Virtuoso. My advice is to ballpark the setup and just let it play for a week or two. I found the break in to be pretty quick. Tweak the settings after break in. Although I wasn't without my cart as long as you I quickly got my ears familiar to an Ortofon budget cart and "forgot" the details of the Virtuoso. It didn't matter though. I know this rebuild sounds better across the board than my stock cart. SS does great work.Please do share your impressions after break in.
Interesting couple of posts about Clearaudio MMs. Thanks.Assuming these are version 1 carts (V2 came out recently) they have identical generators. The Maestro has more wood and sports a boron/microline. The Virtuoso has a stylus/cantilever similar to the AT-95 but with a slightly sharper elliptical. BTW, the new V2 seems to be the same generator with stronger magnets for greater output. The difference between Soundsmith level 2 and level 3 is the tip, which is line contact vs optimised line contact (micro). Previous to this thread I only heard of someone having a level 2 on a Virtuoso. He said it was too bright. I suspect he didn't work out the necessary adjustments. The rake angle of the needle with respect to the cantilever is often different, as Jsm71 said, and you should really approach it as a new cartridge. Glad to hear it's working out. There is no exotic replacement stylus available for these bodies and I think I'll send my Virtuoso in for a stylus lift.neo
