0 Members and 3 Guests are viewing this topic. Read 8701 times.
Wow! Look at that...a cart with headlights... Nice photos...
Cannot get her to track right towards the last 2 tracks. Thinking of using a linear tone arm
What tracks are you talking about that it can't track? Don't be so fast to blame the JMW arm....
I asked the chauffeur to back up. If you don't mind, I'd like to take another look. Please excuse this diversion, it's not really about VPI eye candy, although it is eye catching isn't it? The strain gauge cartridge deserves a thread of its own. Won't track the inner grooves? What a shame. Have you spoken to Peter Soundsmith about this? Why do you have what looks like heavy weight cartridge screws? I suspect you're going in the wrong direction mass-wise. Although actual specs are few and far between on Soundsmith site, it does say the compliance is high. I don't know what the cart itself weighs, but it looks heavy. Does it balance like a "normal" cart?Have you tried aluminum or nylon screws? That would normally be recommended for a heavyweight/high cu cart on a rather light arm. I think Peter would bend over backwards to help you with this dilemma. It doesn't make sense. neo
It's the last 2 tracks at the inner groove. At higher amplitude, there is distortion. Tried my best to align the cart using the supplied protractor, tracking force & azimuth balancing stick etc. Finally concluded that it could be the anti skate force thingy. Tried to email to VPI but did not get a meaningful response. Soundsmith was quite helpful & sold me a special antiskating device for the arm. All I can say is that I am not good at setting up the table. In fact. no one in my whole city knows how to do it properly. I had to purchase another table in my neighbouring country & had the dealers to fly to my place to help set it up. How is that for effort ? They can do a linear tracking tone arm for the VPI. That is at the back of my mind just waiting for the right timing to pull the trigger. Regards,Joe Ling
Souped Up VPI HW-19 Mark IV: Super Armboard, 25 lb TNT Super Platter (the old one, lead impregnated), JMW 10.5i Tonearm, Stand Alone Motor Assembly (SAMA), SDS Motor Controller, HRX Mini Feet, Perimeter Ring, Black Diamond Record Clamp, Customized Acrylic Dust Cover, Customized Rigid Suspension Under the Plinth, Approximately 10 Additional Pounds of Plastic Clay Under the Frame and Plinth, 2 1/2" Maple Block, "Z-Slab" Shelving Mounted on a Zoethecus Stand, 5" Concrete Slab FloorThis is a very heavy turntable. I typically run a Transfiguration Phoenix MC Cartridge, but recently just for grins, swapped it out for a Clearaudio Maestro Wood MM Cartridge, as pictured here. Sounds great!
HW-19 upgraded to Aries/Classic 5.5
Yea... kinda like that!
How does the Maestro Wood compare to the high-end MC? I have a friend who swears by it on any level ($$$) of turntable.
Paul, is that the arm you got from me?
