Clarinet Questions
0 Members and 1 Guest are viewing this topic. Read 2077 times.
JayB
Clarinet Questions
« on: 21 Feb 2013, 05:39 pm »
A few Clarinet questions:
1.   Should wires from the RCA jacks to the PCB be shielded? How about wires to volume controls and selector switches?
2.   Should the screws/nuts used to attach the PCB to the chassis be plastic?
3.   What is the source of the heat that the sinks are supposed to be dissipating?
hagtech
Re: Clarinet Questions
« Reply #1 on: 22 Feb 2013, 01:16 am »
If you design using stock parts, then shielding should not be necessary.  It's all sort of built-in.  For example, several of the heat sinks are used as shields, not sinks.
jh
