0 Members and 1 Guest are viewing this topic. Read 4672 times.
Vudu is the worst? You must live in some bad service area, Vudu on my set comes to about 80% bluray quality, it's actually pretty stunning. The quality depends on your internet speed, mine's very fast and I dont use WiFi.Vudu is easily the best of all services.
Although Netflix will state a requirement of an Internet connection of 3 Mbps for HD content, that only insures that you won't have buffering and stuttering, but the stream will still be automatically downgraded with a higher compression rate if your Internet connection is unable to sustain > 5-6 Mbps.
I have an Oppo BDP-83SE w/ a Pio 720p 42" plasma viewed from 7.5 ft. away & in general greatly prefer DVD upconverted movies/ shows to Netflix & even some Blu-ray transfers.This chart outlines recommended viewing distance in order to see benefits of greater resolution. Most people sit too far away from TV screen to take advantage of greater resolution anyways.
