Modified Cabinet Shape for the 1801
0 Members and 1 Guest are viewing this topic. Read 2507 times.
Kevin
« on: 28 Jun 2004, 11:50 am »
My question is about changing the shape of the box.  I read the little blurb on your WEB site about cabinet shape (http://www.ellisaudio.com/CabinetShape.htm) but I am hoping you have done some experimenting here and can give me some more specific insight.  What I want is a cabinet that has curved sides but not a complete parabola.  The back of the speaker is still flat it is just not a wide as the front.  The back would be maybe 4" wide.
I had thought maybe to build your standard cabinet and then build up layers of MDF on the sides to allow forming the shape I want.  This would however significantly widen the baffle which is probably not a good thing?  If I keep the volume of the enclosure and the width of the baffle  the same as your design can some shape changes be made without affecting speaker performance?  I see that you have made changes in the way you put holes in your internal reinforcing braces.  Has this affected sound colorations?  Egg carton type foam should disperse sound pretty randomly regardless of shape, correct?
David Ellis
    • http://www.ellisaudio.com
Excellent question.
« Reply #1 on: 28 Jun 2004, 12:55 pm »
Even the worst internal shapes (i.e. round) can work just fine with a little foam.  It doesn't take much foam to adequately kill the intenal cabinet modes.
I agree the curved shapes in cabinets look very nice.  Usher, B&W, Sonus Faber all make a very nice looking round back cabinet.  This looks high tech.  It is very appealing to the eye!  I like this look a bunch, and have considered many ways to build such cabinets.  Such consideration is only present because of appearance.  IMO, the only reason to build a nice round cabinet is because they look better.  There are excellent acoustic examples of rectangular cabinets in VERY high end speakers.
F. Alton Everest in the Master Handbook of Acoustics addresses the issue of odd acoustic shapes.  The essential summary is that ALL shapes will have acoustic modes.  The placement of these modes can be altered by the acoustic shape, but the modes WILL be present.  The only real method of dissipating these modes (without absorption) is via diffraction:
http://www.audioholics.com/techtips/setup/acoustics/RPG-Roomacoustics.html
The QRD works.
Now... to your questions:
Er, you should keep the baffle approxomately the same width.  Making the baffle wider will lower the onset of baffle loading in the midrange.  I have not experimented with this, but know that wider is worse.  This is simply because the crossover is designed to chop an appropriate amount of baffle loading for the current design.  Increasing the baffle width significantly will necessitate a crossover change.  The easy fix is to use a significant edge roundover and arrive at about the same baffle width.  The flat portion of the current 1801 baffle is about 7 1/2".  You should aim for this too.
Yep, sure, you betcha'.  As mentioned above, a little foam will cure even the worst cabinet shape.
Nope.
Years ago I was very concerned about breathing room behind the woofer.  I am not significantly concerned about this anymore.  After some experimentation I have learned that a big open area directly behind the woofer isn't very critical.  Some cross braces in this region are just fine.  Futher, when looking at a woofer there is already a big obstruction directly behind the cone.  It's the magnet/motor.  I felt kinda dumb after 1-2 years of thinking about bracing configuration to arrive at this conclusion.  A few cross braces are very minor when compared to that big whopping magnet behind the cone.
Er, egg carton foam shape is simply convenient to cut and use.  It absorbs sound, but has extremely small diffraction effect.  I believe it's safe to eliminate the diffraction effect from the environment.  While there is some diffraction effect, it's extremely small.  Flat foam will work equally well to absorb the sound waves.  This is all you will need to produce the desired effect.
Hopefully my response is adequate.
Kevin
« Reply #2 on: 28 Jun 2004, 01:38 pm »
Thanks Dave!  Yes, this was a more than adequate response.  The sole reason for doing this is aesthetic.  The R&D for using cabinet shape to alter the sound character of a speaker must be painstaking.
I am going to pursue this further.  I am thinking about something in a birdseye maple.
Kevin
David Ellis
« Reply #3 on: 28 Jun 2004, 04:21 pm »
Yes, it is painstaking and pointless too.  Mathematically predicting cabinet modes from odd cabinet shapes - ouch!  Fortunatly this isn't necessary.  As mentioned before, stuffing material will cure bad cabinet shape problems.  If the internal cabinet shape alters the sound character of a speaker then bad things are happening.  The ideal cabinet is completely inert.  Strong walls and good stuffing meet this need.
As you progress through your work please take digital pictures as you are able.  I can post them for you for sharing/documentation.
