0 Members and 1 Guest are viewing this topic. Read 3287 times.
How do they respond? Does it pass? dump to ground? Burn up first in heat dissipation? I'm not sure what is inside of the linear regulators; I just see them used in DC applications. Perhaps they are just the same?
Any typical 3-pin regulator is referenced to ground. The three pins are input, output, and ground. Their normal limits are input voltage (too high and the regulator overheats) and output current (too much demand and the regulator overheats). These are easy conditions to take into consideration in proper design.
