BETA Software for BDP-1 and BDP-2 Feb 1 2013
0 Members and 1 Guest are viewing this topic. Read 7448 times.
unincognito
    • bryston.com
Re: BETA Software for BDP-1 and BDP-2 Feb 1 2013
« Reply #20 on: 8 Feb 2013, 03:01 am »
Hi Marius,
So I hooked up a BDA-1 to a BDP-1 and found the culprit, the digital output is on a different section.  This issue has already come up to support third party DAC's that we would need to develop additional software to detect different audio configuration.
Chris
Marius
« Reply #21 on: 8 Feb 2013, 05:55 am »
Hi Marius
I do not want to list the Juli card anymore as we make modifications to it currently and are moving more and more to other options.
James
Great ! Exciting new options await us!
Marius
unincognito
    • bryston.com
« Reply #22 on: 10 Feb 2013, 03:15 am »
Hi Marius,
Good news the BDA-1 will work through uSB, however the bad news is it won't work due to the current mpd configuration.  But I will see about releasing a version down the road that will allow this.
Chris
Marius
« Reply #23 on: 10 Feb 2013, 08:43 am »
Hi Marius,
Chris
Which is great news on this second day of Carnaval! Thank you Chris!
Cheers and Alaaf,
Marius
afblaster
« Reply #24 on: 14 Feb 2013, 02:55 pm »
Hi Chris,
just to confirm my BDP-1 is working via USB to BDA-1,  - I believe you wrote it wouldn't?
Firmware S1.65 2013-01-30
MPD Ver 0.17.2
SPDIF and USB outputs enabled on mPad
I cannot hear any difference when I switch between the USB and the AES/EBU inputs on the BDA-1.
Regards
Richard
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #25 on: 14 Feb 2013, 03:33 pm »
Hi Chris,
MPD Ver 0.17.2
Regards
Richard
Hi Richard
What DAC are you using?
james
afblaster
« Reply #26 on: 14 Feb 2013, 05:14 pm »
Hi James
Bryston BDA-1
rgds, Richard
« Reply #27 on: 14 Feb 2013, 06:23 pm »
Hi James
Bryston BDA-1
rgds, Richard
Hi Richard
OK so you are not using the USB asynchonous feature available in the BDA-2 USB and you would be limited to 44.1 16Bit.  Still nice to know you are getting output with the new software.  Will wait for Chris to comment as well.
james
Napalm
« Reply #28 on: 15 Feb 2013, 12:52 am »
I submit we should start a new trend, where instead of auditioning cables, fuses, shakti stones and other classic audiophile paraphernalia, we audition various versions of software, and comment on the pinpoint imaging of Beta 2.13 or the fast, tight bass of Beta 2.18....
 :tempted:
unincognito
    • bryston.com
« Reply #29 on: 15 Feb 2013, 04:00 am »
Hi Chris,
MPD Ver 0.17.2
Regards
Richard
Hi Richard,
The current firmware S1.65 doesn't output to a bDA-1 via USB, but it's possible with the addition of some software to detect audio output devices (like a BDA-1 connected via USB) to allow this capabity.  Currently there isn't support but there isn't anything stopping us from making it a reality with the BDA-1.  We are just contemplating how Togo about it, should it be a script that just creates entries for any audio devices that are connected or create a menuing system allow customers to pick and choose.
Chris
adol290
« Reply #30 on: 22 Feb 2013, 01:11 am »
I installed the new firmware, and hooked up a USB cable from the BDP-2 to my SP3.
Switched my SP3 to USB and
the song played just fine.....
