Bordeaux Merrill Audio VERITAS Mono Blocks, Based on Hypex Ncore Nc1200
ua100k
    • Merrill Audio
For Bordeaux color, order before Feb 15th for March 1st delivery.
Engineered from the start to sound the best with no compromise.
Extensive listening tests to get every subtle improvement, down to Custom Power Cords.
Large chassis for electrical and vibration isolation. 17" x 12" x 3"
Attention to every detail, even Litz wire type.
Top of the line components from Cardas, Furutech, Triode Wire Labs, Synergistic Research, Stillpoints.
Enjoy the Merrill Audio VERITAS Mono Block Power Amplifiers in your home system. For a full refund within 15 days, return it in the excellent condition and original packing you received it in.
VERITAS, Greek Goddess of Truth.
Hear the VERITAS Mono Blocks from Merrill Audio in your system
And you will never go back to your current Amplifier.
Features
Solid tight,
controlled bass.
Superbly smooth highs.
Crystal clear micro-detail at low volumes and at high volumes.
Precision image placement and image details.
Very fast, controlled dynamics, at low and high volumes.
One of the most musical Power amps. Uncontrollably toe tapping sound.
Nonexisten
t noise floor.
Details
Merrill Audio VERITAS Mono Blocks based on the Hypex Ncore NC1200 and SMPS1200 power supply, gives you
Large Solid Billet Aluminum Chassis – 17” x 12 x 3” and 30 pounds. It is solid!
Engineered for maximal isolation and separation, and the elimination of microphonics.
Stillpoints UltraMini risers stainless steel
Deeper, more defined bass and clearer highs.
Synergistic Research Tunneled Fuse
Much clearer sound. Like a fog has been removed.
Custom Power Cord from Triode Wire Labs just for the VERITAS Mono Blocks. – The tightest bass and higher, fuller soundstage but not bloated. This is a 10 AWG pure copper, cryogenically treated power cord with copper receptacles with low inductance, low capacitance and low resistance.
Rhodium plated inputs and speaker terminals.
Full signal transfer for clear sound with all the micro details. Gives you precise detail in the sound stage.
Philosophy – Audio Purity
Merrill Audio’s design philosophy is Audio Purity. Everything is engineered to keep the signal path as short as possible, the audio signal pure with every micro detail intact. VERITAS Mono Blocks are engineered for Audiophiles by Audiophile and engineers. Engineered from the beginning to sound the best. Using extensive listening tests on many different systems and by many difference audiophiles and experts, the VERITAS Mono Blocks are developed to be the best possible sound – Truthful.
Price for pair of Monoblocks.
See www.MerrillAudio.net for more information and
For the trade-in program www.MerrillAudio.net/trade-up.html
Specifications
400 Watts into 8 Ohms
700 Watts into 4 Ohms
1,200 Watts into 2 Ohms
2M Input impedance
0.001% THD.
Balanced Input
Dual Speaker Binding posts
35 Pounds each Mono Block
17” x 12” x 3” without footers (add 1 inch for footers)
120V or 220V Factory Set.
5 year transferable warranty.
Made in the US.
Included:
Stillpoints Ultramini Footers
Ma-10 Custom designed power cord from Triode Wire labs with 10AWG cables.
Synergistic Research Fuse
Furutech Gold AC contacts
Rhodium plated Speaker terminals
Rhodium over silver Balanced input pins.
Color on request. NanoCarbon, Bordeaux or Platinum. (4-6 week delivery if not in stock).
Quote from a buyer of VERTIAS Mono Block:
“I have tried MANY amps but could not find the RIGHT one with the BEST sound with also the following: Mono Blocks; True Differential Balanced Inputs; Not to weigh a TON but also to have quality chases; Cool running, for an amp; Quality parts, and no throw away power cords; Sound that is Pure, life like, true to tone, fast with total control of the speakers, real sounding rise and decay of the sound of instruments, deep, wide holographic sound-stage, not sterile but not warm, even sounding from top to bottom, able to reach well into the highs and dig deep into the lows, easy to maintain, no added noise of its' own (I cannot believe how quiet they are) and also musical/toe taping. And the price is NOT an arm and a leg. Yes, Merrill's amps are not inexpensive but to even come close to the sound, let alone everything else Merrill is including, someone would have to spend a HELL of a lot more. I quit after hearing $16,000 to $30,000+/- amps and while some were really great sounding amps, NOT one can give me the sound that Merrill's Veritas amps do.”
www.MerrillAudio.net/veritas.html
Take a look at our Trade-up program also.
