By-Pass Caps Explained
0 Members and 1 Guest are viewing this topic. Read 8350 times.
Re: By-Pass Caps Explained
« Reply #20 on: 1 Feb 2013, 05:16 pm »
Can you elaborate on this? It appears that the circuit transmits the sonic qualities of the by-pass cap, not the main capacitor. How does that occur?
Hi Early,
A typical cap does not discharge or charge fully during a short audio cycle. It never will.
The higher the frequency, the less it accomplishes the task. The much smaller bypass capacitor does
better as the frequency rises, and thus accomplishes what the larger capacitor cannot.
This is a simplistic explanation, but hope it helps Early.
Cheers.
Davey
« Reply #21 on: 1 Feb 2013, 05:29 pm »
Ceramincs are used in auto rigs because of RFI and EMI issues presented by the auto's electrical system.
That is probably what you saw.
No, I'm not talking about just auto gear.  I'm talking about local decoupling near the active devices.  Generally these are ceramic....possibly in combination with a larger electrolytic or possibly a film capacitor.  A lot of digital circuitry in audio gear too.  :)
Whether it's the best capacitor for that job is not really the point.  The reason they are ubiquitous in this application is the cost.
I think some missed the real query that Early B is asking about.  I think it's clear now that's he's referring to the practice of shunting (bypassing) different value/types of capacitors together in audio signal coupling applications.  Probably a high-level speaker crossover network or such.
A considerably different (IMHO) application of the term "bypass capacitor."
Oh well.
Dave.
« Reply #22 on: 1 Feb 2013, 09:50 pm »
Oh well.
Dave.
 I referred to both auto and home applications, including antique, if you look carefully.
Ceramincs won't do the job with electrolytics as the ceramic is way too small. As you
indicate it is cheap and cost effective for the bottom line.
It does, however, as I explained in a previous post, help remove RF and other high frequency problems.
It could be near active devices to accomplish this purpose or to help minimize/eliminate
self oscillation by using a "swamping" method. Unfortunately, that is not good
for the audio signal itself.
Yes, it is used in digital areas and probably in the analog audio path, as it works with very high frequencies,
to remove them. This includes RF.
Bypassing coupling capacitors with ceramics is not a good practice, engineering wise, for the
reasons I outlined in my previous posts.
Cheers.
