Questio regarding WTA system from a new user
0 Members and 1 Guest are viewing this topic. Read 6711 times.
vortrex
Re: Questio regarding WTA system from a new user
« Reply #20 on: 9 Feb 2013, 08:43 pm »
Vortrex you wrote you used to use a 103r what cart are you using today?
I did?  I'm using a 103R.
ace.mcloud
« Reply #21 on: 15 Feb 2013, 01:03 am »
So finally got my whole system setup over the weekend and following about 20 hours of listening or so I can say that it sounds great and should only be better !!
The setup for the most part was alright except for the EMT cart. That thing has hardly any body on it and its magnetic !
I am curious to know if anyone has heard the Amadeus with a slight negative VTA? Being told that for rock music it's a better option.
Ace
Erocka2000
« Reply #22 on: 15 Feb 2013, 03:23 am »
I set mine with the tail down a little bit, as you've mentioned, and have the ball about a 1/4 into the goop.  I feel like I've got it perfectly dialed in for my preferences.
And I know what you mean regarding the install of the EMT. Definitely not for the faint of heart ;)
Congrats on the system again!  Enjoy.
