CIA USB Transcient Mk II & JRiver
birddogthecat
« on: 24 Jan 2013, 12:16 pm »
Is there an incompatibility problem? Are there JRMC settings that must be changed?
CIAudio
Re: CIA USB Transcient Mk II & JRiver
« Reply #1 on: 24 Jan 2013, 03:26 pm »
Transient MKII is fully compatible with JRiver. You can call us if you need any installation assistance.
Starchild
« Reply #2 on: 18 Jan 2014, 02:33 am »
Does that mean that the audio engine and other features in JRiver will work with the Transient MkII?
CIAudio
« Reply #3 on: 20 Jan 2014, 06:01 pm »
I'm not sure what you mean by "Audio Engine", but I assume you're talking about the various output options.
Once you install our driver, you select ASIO from the Output Mode drop down list. Wasapi and others are also supported.
« Last Edit: 20 Jan 2014, 09:05 pm by CIAudio »
Starchild
« Reply #4 on: 24 Jan 2014, 05:29 am »
There are numerous features in JRiver such as DSP, volume leveling etc... that are non-functional when utilizing dlna which is what I'm using now (Oppo 103).
