0 Members and 2 Guests are viewing this topic. Read 142930 times.
close-up pictures would be nice
...look at the panel terminal. If it's a rivet, if you don't see a screw head (my repair) or nut (Brian's repair), if I was you I'd update the panel ASAP...
Yes I think I have answered my questions with this post from Long Ear regarding an email he got from Brian: http://www.audiocircle.com/index.php?topic=96810.msg971709#msg971709So to sum it up, the Ultra Megawoofers appear to be:Dayton Audio RSS390HF-4 15" Reference HF Subwoofer 4 OhmBrand: Dayton Audio | Model: RSS390HF-4 Dayton Audio RSS315HF-4 12" Reference HF Subwoofer 4 OhmBrand: Dayton Audio | Model: RSS315HF-4If using the Dayton Audio HPSA1000-R 1000W Rackmount Subwoofer Amp, wire the two drivers in serial or use another amplifier that is capable of driving a 2 ohm load (like the Crown versions mentioned in the thread).Surgery is required due to the larger diameter of the aforementioned drivers as John mentions.gab
...If I recall it correctly I placed nuts out because nuts were larger than a screw head or washer. Having nuts on the inside could cause shorts since there is really little space between leads, some 0.5 mm or so...
Have 2 additional 15" Passive radiators (old style) non-vitrified for $39 each plus shipping.
are they rubber surrounds or foam?
I'm interested to see reply. While I worked for Brian every PR had exclusively foam surround.In VMPS lingo, does not "vitrified" indicate PR cone coated with white wood/paper glue? We're going way back, but that's my recollection...http://dictionary.reference.com/browse/vitrified
GOOD NEWS for those of you with Classic VMPS with "DYNA-RIBBONS".This includes Early FF-1 and FF-3 owners.We have uncovered 15 of the DYNA-RIBBONS (see photo below) $99 plus shipping.I will update the INVENTORY page.
