Importing to iTunes funny Kbps
0 Members and 1 Guest are viewing this topic. Read 777 times.
jparkhur
« on: 21 Jan 2013, 07:04 pm »
Hey,
I am reimporting all of my music in to iTunes at AIFF.  Question.. Why are some coming in at a higher kbps rate than others?  Will they still play out of my usb DAC?
Thanks   Image below of kbps? See the AIFF at 1144 kbps?
toddbagwell
Re: Importing to iTunes funny Kbps
« Reply #1 on: 21 Jan 2013, 07:41 pm »
FLAC and ALAC are lossless compression formats, but with the compression comes a reduction in bitrate, which it looks like you've got with the apple lossless files in your image.
AIFF and WAV will always be 1411 kbps for 2 channel, 16 bit, 44kHz material.
you can convert from one to another and you'll not lose any info.
todd
