Affordable amp. up to $1200
0 Members and 1 Guest are viewing this topic. Read 5352 times.
roscoeiii
Re: Affordable amp. up to $1200
« Reply #20 on: 21 Jan 2013, 07:03 pm »
Hi and thanks! I just got back from a trip, so I will be looking of what you've listed here right on.
Best regards and thanks again. I'll be in touch soon.
But what are your speakers? Choosing an amp needs to involve matching an amp with speakers.
And it may be that you will not find a tube amp in your price range that is a good fit for your speakers if they have certain characteristics (requiring lots of power or due toimpedence issues).
Demerara
« Reply #21 on: 21 Jan 2013, 09:03 pm »
Hi,
I just stumbled across your post and I am helping a friend right now with more or less the exact same question.  As many have noted you have not indicated the speakers you wish to use which would help considerably.  Nonetheless I would highly recommend this:
http://www.musicalparadise.ca/store/index.php?route=product/product&product_id=55
It is likely not well known, but is really an outstanding amp, capable of driving almost any speaker with authority.  They provide a small window to return the amp if it really does not suit you but I think upon hearing you will be convinced.  It probably sounds like I represent Musical Paradise (not the case) since this is my first post, but just wanted to spread the word about an excellent amplifier that falls within your stated budget.
