0 Members and 1 Guest are viewing this topic. Read 5397 times.
>------------| | \ / \<--------------> out / | | ____ ___ _
(1) I only have limited stuff on hand : a 100k linear dual gang 4 leg pot and two 180k 1% resistors, some decent silver wire and connectors etc.I'm thinking of using those bits to put together a passive pre, but I'm not 100% sure about which pins I should hook up and whether the 180k resistor will be ok...(2) I think 2 is the wiper. Resistance between 1 +2 and 2 +3 are inverse. Between 1 + 3 always 100k. Between 2 and 4 goes from 50 to 0 (3) I'm going from a DAC to an old Toshiba Aurex power amp. The Tube pre really wasn't suitable for where it was as you couldn't really go past 10 o'clock and TBH a passive pre is probably more suitable here anyway.
(2) Any standard pot gets only 3 pins to hook up. Following the same configuration of yr link, pin 1 is correct, pin 2 is for O/P to yr power amp. Pin 3 is for the signal return "ground".
No, I'm afraid not.In his photo, if the control is turned fully CCW (minimum volume) pin 1 and pin 2 are now common. Pin 2, being the output, should be at ground with this rotation position.So, Pin 1 ground, Pin 2 output, Pin 3 input.Cheers,Dave.Yup, so reverse the pin connection on pin 1 & pin 3.c-J
Marbly,this is what it looks like.I got that wood from the hobby shop and had a trophy store make me a ingraved name....Mark KordaIt's a massive passive preamp so I rowed my dory up on it at high tide and waited for low tide to show the scale! I used knobs from a Dyna PAS-2.....Mark Korda,Portland,Me.
One common overlooking by many DIYers is the proper running of the signal & signal return ("ground") wiring, active or passive regardless. The "ground" wiring of yr linestage needs re-run properly to get better sound, IMO.For all the passive linestages I built, I pay tons of attention on signal & signal return ("ground") wiring.
Hi c-j,Can you be a little more specific about grounding. I'm always looking for better ways to improve my passive volume control. Tips and tricks, etc.Thanks man!,Q.E.
