Anyone interested in a low cost DC blocker box?
0 Members and 1 Guest are viewing this topic. Read 38229 times.
mtruong34
Re: Anyone interested in a low cost DC blocker box?
« Reply #80 on: 20 Feb 2013, 08:52 pm »
The amps are TRL Samson, 300WPC.  From day one they've had slight mechanical hum.  Nothing earth shattering but I wouldn't mind zapping the hum for peace of mind.
" Plug your power amplifier into one of its AC outlets, and your preamp or a AC terminal strip for the rest of your equipment into its other AC outlet and DC related hum will be dinged. "
Would plugging 2 AC terminal strips be too much?  One side for the mono's and the other side for preamp and DAC?
« Reply #81 on: 20 Feb 2013, 09:49 pm »
Nice clean little package Frank & Co. Well done. And at your usual more bang for the buck price.  :thumb:
Denverhifi
« Reply #82 on: 4 Mar 2013, 08:57 pm »
As of March 1st, I'm now on the waiting list.
My first AVA product, and my first post on Audiocircle.
Patrick
Denverhifi
« Reply #83 on: 18 Apr 2013, 02:35 am »
Patrick
My Humdinger was shipped today!
Denverhifi
« Reply #84 on: 22 Apr 2013, 06:27 pm »
It arrived on Friday. In February I got a Emotiva XPA-2, and plugged it into the wall. That's when the hum started, and it ended when I plugged in the Humdinger.
Is there any concern about placement in relation to cables, wires, etc.?
Patrick
doctorcilantro
« Reply #85 on: 26 Oct 2013, 01:18 pm »
I'm going to call and try to order two of these. Was looking for something like this.
rikhav
« Reply #86 on: 11 Dec 2018, 02:15 am »
Can this device be used for a 230 V power line or there is a different version to be used with 230 line
avahifi
    • http://www.avahifi.com
« Reply #87 on: 12 Dec 2018, 03:28 pm »
Our HumDinger will work just fine on 220-240 V AC.
However the HumDinger chassis is designed for 120V USA three conductor AC outlets only.
The workaround is to order inexpensive adaptor cables from stayonline.com.
Thanks for your interest.
Frank
rikhav
« Reply #88 on: 12 Dec 2018, 04:10 pm »
Hi Frank
Thanks for your reply
What you mean is I will need power cable with US type connector's?
If yes then I can always get power cables with US connector's
rollo
  • Rollo Audio Consulting -
« Reply #89 on: 12 Dec 2018, 05:17 pm »
  Great idea Frank and priced fairly. Good job.
charles
avahifi
« Reply #90 on: 12 Dec 2018, 07:10 pm »
Yes, for 220 - 240V operation, you will need power cords with USA connectors on the ends that plug into the HumDinger AC outlets.  The Humdinger AC in uses a standard IHF power cord plug in jack.
Here is the link to the Humdinger at our web site.  Note that it should not be used ahead of a line conditioner. These have very undocumented arrays of inductors, capacitors, and who know what else that may cause the HumDinger to overheat.  It is fine to use after the line conditioner.
https://avahifi.com/collections/accessories/products/humdinger-dc-line-blocker
Frank
srb
« Reply #91 on: 12 Dec 2018, 07:16 pm »
Do you mean IEC, specifically IEC C14 (that accepts C13 plug connectors)?
rikhav
« Reply #92 on: 12 Dec 2018, 07:18 pm »
Thanks for reply again
Absolutely no type of  conditioners used
So it should be OK
It's for a friend whose Karan acoustics integrated amp transformer is humming way too loud but only in his apartment. We tried at two more places, one in the same building but no humming what so ever
avahifi
« Reply #93 on: 12 Dec 2018, 08:08 pm »
I am not up to speed on the names of IEC connectors.  I mean the standard USA 3 conductor AC plug socket that matches all of those power cords out there in the USA.  Look at the link to the Humdinger above and look at the photos of both ends.
Frank
rikhav
« Reply #94 on: 20 Dec 2018, 04:03 am »
Hi Frank
My friend has placed the order of the humdinger and it should reach us within few days
Anything specific we will need to do before connecting it to a 240v power supply?
groovybassist
« Reply #95 on: 20 Dec 2018, 04:10 am »
I use a Humdinger with my Karan Acoustics integrated amp as I had the same hum problem after I moved to a new place.  Works great and the amp is dead silent now.
rikhav
« Reply #96 on: 20 Dec 2018, 05:03 am »
I am so happy to read your message since you have the same amp what my friend uses
He bought the amp on my recommendation and it truly sounds very good
Issue I'd it only hums at his house and not at 3 more places where we tried.
Once we install the humdinger I will surely update the thread with my findings
Wayner
« Reply #97 on: 20 Dec 2018, 08:25 pm »
The Humdinger will accept an IEC-13 power cord. (standard)
Wayner
« Reply #98 on: 20 Dec 2018, 08:26 pm »
Hi Frank
Hopefully its not supplied with an IEC-13 connector, which would violate CE rules.....
avahifi
« Reply #99 on: 20 Dec 2018, 11:44 pm »
Go to Stayonline.com for the appropriate adaptor for 240V for your country.
Frank
