shuffling.....
santacore
shuffling.....
« on: 14 Jan 2013, 03:15 pm »
Hey guys,
I'm running a headless Mac Mini server, using iTunes 11, and Audirvana Plus(Amarra hasn't been stable for me). I use the Remote app on an iPad to control the system. Everything was working fine until a few days ago. Basically, no matter what album I choose, after playing 1 song, it shuffles to another artist whose song happens to be in alphabetical order in my library from whatever I played. I checked to make sure shuffle and like setting are off, but I can't get it to stop. I can't just play 1 album all the way through, iTunes is constantly shuffling to the next alphabetical song title regardless of artist.
I've been using an iTunes / Amarra or Audirvana software system for years and haven't had a problem like this. Either it's an iTunes 11(never should of upgraded) screw up or I accidentally selected something without knowing it.
Any help would be appreciated.
jparkhur
Re: shuffling.....
« Reply #1 on: 14 Jan 2013, 03:41 pm »
If i right click on the album in picture mode, i have a choice of shuffle album.  You are correct in that things changed at last update somehow.  If I am in a playlist, it only shuffles the play list as suppose to.
Does this help???
santacore
Re: shuffling.....
« Reply #2 on: 14 Jan 2013, 04:09 pm »
No, but thanks for trying.
It seems my system is shuffling all songs in my library according to their alphabetical order, regardless of which artist or album I choose. For example, if I want to play a Hendrix album, it will play the first song, and then shuffle to another artist whose song comes alphabetically in my library right after whatever the title of the Hendrix song I played. So I can't play a album straight through, I'm in constant shuffle alphabetically by song mode. Weird!!!!
jparkhur
Re: shuffling.....
« Reply #3 on: 14 Jan 2013, 04:11 pm »
Click on album in the middle first and then try it....   works here...
Crimson
Re: shuffling.....
« Reply #4 on: 14 Jan 2013, 04:51 pm »
You may want to reattach a head and see if iTunes has somehow been changed to sort by song, or some other such issue.
santacore
Re: shuffling.....
« Reply #5 on: 14 Jan 2013, 05:36 pm »
Okay, I think it's back to normal. I used screen sharing to control my mini, and selected sort library by genre. I believe it was as simple as that to fix. It seems like a weird bug, since I never had shuffle or random play selected. Hopefully it's back to normal for good.
abernardi
Re: shuffling.....
« Reply #6 on: 15 Jan 2013, 05:01 am »
I've had a similar problem with the same setup - headless mac mini, itunes 11 and Audirvana using remote on the ipad.  But for me it was a little different.  I was playing a Rickie Lee Jones album and then chose a different album on the iPad.  But it just started playing the Rickie album again.  It didn't matter what song I chose to play next on the ipad, it just went to another song on the same album.  Then I noticed that even though it was staying in the same album regardless of what I was choosing on the iPad, the cut numbers were identical.  So if I chose cut 3 from some other album, it would play cut 3 on the same Rickie Lee Jones album.
  Then I too went to screen share on my Imac and took it out of album mode and put in song mode and the problem was gone.  I think what happened was that I started playing the Rickie Lee Jones album from my Imac and when I tried to change things using Remote on the Ipad, it got stuck in that album, until I changed it from the Imac.  I think this is a bug with Audirvana and iTunes 11.
