Looks like some good stuff. Can you list the gear you are using with the Pioneers?
I moved some equipment around. Put this system together and the Pioneers sound pretty good. They image very well and have an eerily deep soundstage.I just spent some quality time with this set up. I pulled out a tape measure and aligned the speakers, swapped out some amprex tubes for some tele-fu-kens and WOW! Talk about hitting way above their price point. These little (stock) Pioneers sound great with some modest gear behind them. I think I hit a synergy home run.Maybe I should mod them
So Amazon has the FS52 on sale for $60 each.
I suspect that those that are trying to remove the speakers from the cabinets are using US version allen wrenches, which would be wrong. The drivers are 2.5mm allen size. My 2.5 fits perfectly and all of the screws came lose with no problem.If you think you have stripped out the wood screw threads, buy some extra 2.5mm allen wrenches, and apply some 5 minute epoxy to the end that you insert into the allen headed wood screw, let it dry and then pull out as you turn the screw counter-clockwise.Or better yet, use some super glue on the allen wrench and when you have the screw out, put the glued allen wrench/screw above a flame and it will "un-bond" the super glue, so you can use the screw (and wrench) again.Wayner
Someone just asked about buying my Lore's which got me thinking about my Pioneers again. These woukd become my speakers for awhile. Would just coating the interior of the cabinet (and frame of woofer and maybe tweeter) in plasticlay help significantly?
Thanks. I may even go with the bitumen route..
For those who may be interested - the modded Pioneer speakers are now online.http://philharmonicaudio.com/folio-me/html/Phil%20Pages/AALS.html
Am I crazy, or did Dennis comment that the modded C22 would not make a great main speaker due to the cabinet tuning? I thought he did, but can't find that comment.
I hope to finish up mod for the center channel over the next couple of days. ( I was a little disappointed to discover that the center channel is tuned significantly higher than the 22's, due to the cabinet volume being less than twice that of the single-woofer 22. So I think that will have to be used strictly as a center rather than a bargain MTM main.)
Thanks. I may even go with the bitumen route even for the bookshelves because I am a bit lazy. Or maybe a mix of both where I can get them in. I doubt I'll let the Lore's go, but you never know. I now wish I bought a better amp and waited to buy speakers for the amp that I loved.
