Setting up a TT after 10 years
0 Members and 1 Guest are viewing this topic. Read 8986 times.
poseidonsvoice
    • 2 channel/7 channel setup
Re: Setting up a TT after 10 years
« Reply #40 on: 12 Jan 2013, 01:22 am »
Wirenut,
Given that you are a diy'er:
http://www.audiocircle.com/index.php?topic=112962.msg1174243;topicseen#new
or the Bugle, or Cornet 2 (if you can afford the final cost of the build, given your $300 ceiling)
Best,
Anand.
Here's another one I found by Greg Ball: RIAA. Fully built for $100 Australian dollars. Not bad.
Best,
Anand.
WireNut
« Reply #41 on: 15 Jan 2013, 02:47 pm »
 How do I know if my stylus needs to be replaced ?
 Will it just die or will It sound distorted  :scratch:
SteveFord
« Reply #42 on: 26 Jan 2013, 01:33 pm »
It will sound dull and possibly distorted.
You'll need a microscope to be shure (little pun).
If it's cheap enough just replace it to be on the safe side.
