8" Single Servo Sub
0 Members and 1 Guest are viewing this topic. Read 49702 times.
mlundy57
Re: 8" Single Servo Sub
« Reply #100 on: 28 Jan 2014, 02:04 am »
HX580 (we should have name these HX600, but we already have a model H600, so we name the amp HX580 to avoid confusion) has list price of $379, and HX300 has a list price of $289. Please note each HX amp is a mono amp regardless how many Ucd modules it uses.
We do encourage the customers to use a pair of HX580 driving four DS800, we have a package price of $1179 for that.
How would you connect a stereo amp that has a second set of L/R line level pre-outs but does not have a summed subwoofer pre-out like an AVR has?  The sub I am currently using in this system has L/R line level inputs so connection is simple: L/R pre-amp outputs to L/R sub inputs. However, the HX580 appears to only have a single input.
Mike
MarvinTheMartian
« Reply #101 on: 29 Jan 2014, 12:38 am »
Mike, You answered your own question.
"Please note each HX amp is a mono amp"
"We do encourage the customers to use a pair of HX580 driving four DS800"
I'm more interested in a pair of HX580 driving eight DS800 : )
As a solid base (bass) for a pair of N2X or N3S.
Shawn
mlundy57
« Reply #102 on: 29 Jan 2014, 02:00 am »
That poses a real problem for me with these subs. I'm not interested in $1,200 worth of subwoofer components to match up to $189 of speaker components in a desktop system.
Maybe they aren't going to be the answer I thought they would be after all  :(
Mike
Danny Richie
« Reply #103 on: 29 Jan 2014, 02:21 am »
Mike
I have some non-servo 8" woofers that were used in the X-Sub that I can sell you for $25 a piece.
kc8apf
  • Are you sure what side of the glass you're on?
« Reply #104 on: 29 Jan 2014, 02:29 am »
Are the X-Sub plans still available?  I was hoping to do a 8" servo sub to pair with X-LS but a non-servo 8" would probably work just as well.
mlundy57
« Reply #105 on: 29 Jan 2014, 02:36 am »
I'm not familiar with the X-Sub. What amp would you drive them with?
Mike
slosjo
« Reply #106 on: 29 Jan 2014, 02:50 am »
Mike
+1.
I might up for trying out a 8" non servo amp sub combo if the price is right.
Danny Richie
« Reply #107 on: 29 Jan 2014, 04:43 am »
I can send you box plans.
It is not going to be in the same league as the servo sub, but it has a high bank for the buck.
I just have the woofers. You'll have to pick up an inexpensive plate amp from PE or something.
mlundy57
« Reply #108 on: 29 Jan 2014, 04:46 am »
Thanks Danny
I could use a copy of the box plans as well.
Mike
Danny Richie
« Reply #109 on: 29 Jan 2014, 04:56 am »
It's a down firing design that I drew out with metric measurements for the guys in China.
http://gr-research.com/pdf/X-sub.pdf
mlundy57
« Reply #110 on: 29 Jan 2014, 05:12 am »
Thanks Danny
What type of low end extension will this sub provide?
Mike
Danny Richie
« Reply #111 on: 29 Jan 2014, 05:33 am »
Thanks Danny
Mike
-3db down was 28Hz.
mlundy57
Danny Richie
« Reply #113 on: 29 Jan 2014, 06:12 am »
I am not a big fan of the Bash amps. But that little Dayton amp will work just fine.
mlundy57
« Reply #114 on: 29 Jan 2014, 06:19 am »
Huston we have lift off
Looks like I have another speaker or two to build
I found this thread with some build pics of the X-Sub box design
http://www.audiocircle.com/index.php?topic=91095.msg905756#msg905756
Love those build threads. You never know when one will come in handy
Mike
mlundy57
« Reply #115 on: 29 Jan 2014, 05:09 pm »
Just got off the phone with Danny. To clarify, all that is needed to sum the stereo output from the preamp into a mono signal to connect to the 8" servo sub is a Y-jack. So the 8" servo subs can be used with a preamp even if it doesn't have a subwoofer output channel.  :thumb:
I'm still going to build a couple of small single driver non-servo subs and possibly a dual driver version as well.
Mike
« Last Edit: 29 Jan 2014, 06:27 pm by mlundy57 »
jeffh
« Reply #116 on: 29 Jan 2014, 07:33 pm »
Can somebody drawn a picture of this?
Do you split the signal between the pre-amp and the amp or do you split the speaker output from the amp? What does the splitter look like electrically?  Or can you just connect two speaker cables from the amp out with one going to the speaker and the other going to the sub?
Is this what is needed:     http://shop.emotiva.com/collections/accessories/products/xrca-1x2
Danny Richie
« Reply #117 on: 29 Jan 2014, 08:26 pm »
Here let me draw you a picture.
Y
That's what it looks like. :thumb:
Danny Richie
« Reply #118 on: 29 Jan 2014, 08:30 pm »
Ideally though you want one with a male end that you can plug right into the amp.
Here is an example: http://www.parts-express.com/gold-rca-y-(1)-male-to-(2)-right-angle-female-red--091-510
And then plug in an left and right input from your pre-amp.
WhereitsAT
« Reply #119 on: 30 Jan 2014, 01:56 am »
Looks like a great design!
