0 Members and 1 Guest are viewing this topic. Read 16807 times.
I read that one should use shorting plugs for rca inputs and non-shorting caps for the outputs.
The only difference is decorative.
What about preamps with both balanced and unbalanced inputs. Is there anything that must be done to the balanced inputs to acheive the benefit?
Gee, and here I thought the OP was asking about simple caps for the RCA's on his equiptment. Keep it simple.
Are you the same Elizabeth as the one on A-gon? Just curious.
