Merrill Audio VERITAS Mono Blocks in Platinum - order now for Jan delivery.
ua100k
    • Merrill Audio
Item Description
Powerful * Musical * Fast
STOCK SOLD OUT FOR 2012. - Next availability Jan 15th, 2013. Place your order now to get in the production queue.
Try them in your home, Hear the magic. MADE IN THE USA.
Trade in program available for limited time.
Call or email to get a valuation as part of your trade-in purchase of the VERITAS Mono Blocks.
Testimony - From the owner of the $85,000 Pipedream speakers….
“Merrill Audio VERITAS Mono Blocks driving the Pipedream Prototype vertical line source with 56 1-inch silk dome tweeters mounted vertically 6 inches directly in front of 16 mid-range drivers strung with 2500 feet of pure silver/teflon wire. The amps displayed excellent imaging, staging and detail when fitted with the power cords supplied with the amps. The owner, a tube amp lover with a pair of Melos 402's, stated this was among the most enjoyable solid state amps he has had in his system.”
Why are the Merrill Audio VERITAS Mono Block Power Amplifiers so good.
Engineered from the start to sound the best with no compromise.
Extensive listening tests to get every subtle improvement, down to Custom Power Cords.
Large chassis for electrical and vibration isolation. 17" x 12" x 3"
Attention to every detail, even Litz wire type.
Top of the line components from Cardas, Furutech, Triode Wire Labs, Synergistic Research, Stillpoints.
Enjoy the Merrill Audio VERITAS Mono Block Power Amplifiers in your home system. For a full refund within 15 days, return it in the excellent condition and original packing you received it in.
VERITAS, Greek Goddess of Truth.
Hear the VERITAS Mono Blocks from Merrill Audio in your system
And you will never go back to your current Amplifier.
Features
Solid tight,
  • controlled bass.
    Superbly smooth highs.
    Crystal clear micro-detail at low volumes and at high volumes.
    Precision image placement and image details.
    Very fast, controlled dynamics, at low and high volumes.
    One of the most musical Power amps. Uncontrollably toe tapping sound.
    Nonexisten
t noise floor.
Details
Merrill Audio VERITAS Mono Blocks based on the Hypex Ncore NC1200 and SMPS1200 power supply, gives you
Large Solid Billet Aluminum Chassis – 17” x 12 x 3” and 30 pounds. It is solid!
Engineered for maximal isolation and separation, and the elimination of microphonics.
Stillpoints UltraMini risers stainless steel
Deeper, more defined bass and clearer highs.
Synergistic Research Tunneled Fuse
Much clearer sound. Like a fog has been removed.
Custom Power Cord from Triode Wire Labs just for the VERITAS Mono Blocks. – The tightest bass and higher, fuller soundstage but not bloated. This is a 10 AWG pure copper, cryogenically treated power cord with copper receptacles with low inductance, low capacitance and low resistance.
Rhodium plated inputs and speaker terminals.
Full signal transfer for clear sound with all the micro details. Gives you precise detail in the sound stage.
Philosophy – Audio Purity
Merrill Audio’s design philosophy is Audio Purity. Everything is engineered to keep the signal path as short as possible, the audio signal pure with every micro detail intact. VERITAS Mono Blocks are engineered for Audiophiles by Audiophile and engineers. Engineered from the beginning to sound the best. Using extensive listening tests on many different systems and by many difference audiophiles and experts, the VERITAS Mono Blocks are developed to be the best possible sound – Truthful.
Price for pair of Monoblocks.
See www.MerrillAudio.net for more information and
For the trade-in program www.MerrillAudio.net/trade-up.html
Specifications
400 Watts into 8 Ohms
700 Watts into 4 Ohms
1,200 Watts into 2 Ohms
2M Input impedance
0.001% THD.
Balanced Input
Dual Speaker Binding posts
35 Pounds each Mono Block
17” x 12” x 3” without footers (add 1 inch for footers)
120V or 220V Factory Set.
5 year transferable warranty.
Made in the US.
Included:
Stillpoints Ultramini Footers
Ma-10 Custom designed power cord from Triode Wire labs with 10AWG cables.
Synergistic Research Fuse
Furutech Gold AC contacts
Rhodium plated Speaker terminals
Rhodium over silver Balanced input pins.
Color on request. NanoCarbon, Bordeaux or Platinum. (4-6 week delivery if not in stock).
Quote from a buyer of VERTIAS Mono Block:
“I have tried MANY amps but could not find the RIGHT one with the BEST sound with also the following: Mono Blocks; True Differential Balanced Inputs; Not to weigh a TON but also to have quality chases; Cool running, for an amp; Quality parts, and no throw away power cords; Sound that is Pure, life like, true to tone, fast with total control of the speakers, real sounding rise and decay of the sound of instruments, deep, wide holographic sound-stage, not sterile but not warm, even sounding from top to bottom, able to reach well into the highs and dig deep into the lows, easy to maintain, no added noise of its' own (I cannot believe how quiet they are) and also musical/toe taping. And the price is NOT an arm and a leg. Yes, Merrill's amps are not inexpensive but to even come close to the sound, let alone everything else Merrill is including, someone would have to spend a HELL of a lot more. I quit after hearing $16,000 to $30,000+/- amps and while some were really great sounding amps, NOT one can give me the sound that Merrill's Veritas amps do.”
www.MerrillAudio.net/veritas.html
Take a look at our Trade-up program also.
jtwrace
    • TIPP YouTube Channel
Made in the US.
You mean ASSEMBLED IN THE USA.
ua100k
    • Merrill Audio
Designed, tested and handcrafted in the United States of America.
The parts are from USA, Japan, Netherlands and I am almost sure there is a washer at least from China. Sold Worldwide.
« Last Edit: 21 Dec 2012, 07:19 pm by ua100k »
ua100k
    • Merrill Audio
Merry Christmas and Happy New Year!
« Reply #3 on: 22 Dec 2012, 03:23 am »
jhm731
Mele Kalikimaka to the "all."
Just wondering, how many people other than you represent the "all" at MA?
PS- You need update your photos to show the UltraMinis instead of the MiGs.
ua100k
    • Merrill Audio
Mele Kalikimaka - Go rainbows! UH Alumni.
Good idea on the stillpoints!
15 vendors, 8 advisers, 4 EE, 3 board, and a partridge in a pear tree.
