0 Members and 1 Guest are viewing this topic. Read 15375 times.
J Gordon Holt is right when he says that when a recording is made on site the ambience of the locale is already in the recording. At least it is in analog made recordings. This is what has kept me away from Maggies for so many years, but I'm trying to hear some 1.7's locally to see what I think in actual practice. JohnR is calculating the delay as the time it takes to hit the wall and the time it then takes to reach the plane of the speaker coming the other way*. I can give the speakers 5' off the wall and nothing more. So, to calculate the time delay should I multiply the distance to the wall behind times 2?Next question. How low should the crossover point be to a single bass panel? The reason I am asking this is because I would try to get by with one panel if the signal is undetectable as mono. Or, is that even possible?Thanks.*Is that right, JR?
I can give the speakers 5' off the wall and nothing more. So, to calculate the time delay should I multiply the distance to the wall behind times 2?...*Is that right, JR?
Aha, Google image search reveals all:I also found http://www.avguide.com/review/magnepan-s-mini-maggie-speaker-system-revisited-playback-53?page=1, which says "DWM uses a planar magnetic mid/bass panel that, by design, features dual conductors or “voice coils” (one set for the left channel of the Mini-Maggie system, the other for the right channel). Note, however, that while the DWM panel can be used with two-channel inputs, it also works fine with a single-channel input."
Thanks Josh and John for your replies. Nicely comprehensive. I understand. Cheers. Because I listen mostly to acoustic music made on location I am excited to demo the 1.7's at my earliest.Think I can get some improvement with one bass panel? I know two would be better but that's not the question. Should the bass panel be out from the wall, too, and is it bi-directional like the main panels? Thanks in advance.
Thanks, Josh. I remember now seeing the recommended way the panels are set up at the Maggie's site and that would work well in my room. Where ya'll put all these amps? I have two monoblocks for the main speakers. Other than those, I would be outta pocket some more moola. I don't suppose they are active?
Luckly, if your amps can drive a 4 ohm load as I'm sure they can, you don't usually need extra amps. You just hook them up in parallel with your main speakers, usually with a resistor to reduce the level a bit. The resistor keeps the impedance from falling too low.
Oh, wow. That's certainly what I would try. My amps are Kenwood L07M's rated at 150w into 8ohms. I don't know how stout they are at 4.
See:http://www.thevintageknob.org/kenwood-L-07M.html
Power :1x 150W (20Hz...20Khz, 8 Ohm, 0,008% THD) 0,007%THDContinuous power :1x 150W (8Ohm, 1Khz)Dynamic power :1x 200W (4Ohm, 1Khz)1x 300W (4Ohm, 1Khz) 1x 250WWell, what do you guys think of these specs from the link provided by most cool jhm ? Help me understand the bit on the end of the following- 1x 300W (4Ohm, 1Khz) 1 x 250W (?). Thanks.
Thanks, Don. If I'm reading the bottom line right, the power doubles into 4 Ohms, 150w to 300w for the LO7 and 250w for the Mark II. The line just above, however, reads only 200w but what the difference is, is unclear to me. Any guesses as to why there is a difference? And if I were to hook up a bass panel in parallel with a main panel to the amp, what if anything happens to the dynamic output? Still capable of 300 watts? Thanks.See:http://www.thevintageknob.org/kenwood-L-07M.htmlAnd, do the 1.7's require a lot of damping factor to control the panels? 100 (8Ohms) enough? Is more desirable?
Thanks, Don. If I'm reading the bottom line right, the power doubles into 4 Ohms, 150w to 300w for the LO7 and 250w for the Mark II. The line just above, however, reads only 200w but what the difference is, is unclear to me. Any guesses as to why there is a difference? And if I were to hook up a bass panel in parallel with a main panel to the amp, what if anything happens to the dynamic output? Still capable of 300 watts? Thanks.See:http://www.thevintageknob.org/kenwood-L-07M.htmlAnd, do the 1.7's require a lot of damping factor to control the panels? 100 (8 Ohms) enough? Is more desirable?
Thanks Josh and John for your replies. Nicely comprehensive. I understand. Cheers. Because I listen mostly to acoustic music made on location I am excited to demo the 1.7's at my earliest.Think I can get some improvement with one bass panel? I know two would be better but that's not the question. Should the bass panel be out from the wall, too? Is it bi-directional like the main panels? Thanks in advance.
