Some of you guys are covering up the air vents on these headphones with your duct tape. I don't recommend it because it allows more air into the headphone, kind of like a ported speaker allowing a smaller cabinet.
The vents you're talking about are only those three holes already lightly covered up by the white factory tape, right?
DOS your right about the vents! I just removed the tape covering them and the "air" is back with a more realistic sound.With the vents covered the bass would decay rather quickly and drop off severely.With the vents open there is more space around the notes, and sound more natural.Thanks for the tip.
NOTE TO SELF: Stop reading this frickin thread or you will never be done modding these cans
Removing the tape is the last mod I will do to these phones.
I considered intentionally stripping the screws this morning to ensure I am not tempted to do any future mods
This stuff can drive you nuts if you let it!
Now I'm wondering if you stuffed the cabinet with something, would it make sense to remove the factory tape we have been talking about? The tape was originally meant to provide resistive air movement, but with a stuffed body we have doubled the resistance to some degree. The question being, would it reduce bass just a little bit?
In your case if you like less padding in the back try opening one port at a time. You wouldn't want to over-do it right? That factory tape is some weird stuff I haven't seen for sale personally. It doesn't even come off easily (I wanted to pull it off, but I had to cut it out).
